![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 12, '05 From Texas Currently Offline Reputation: 59 (100%) ![]() |
question:
My int. dimmer is not working...yes it is getting power...what is going on? if you can tell me soon, hope to get this figured out quick...getting dark! thanks, snap edit: my lower part of the dash is in pieces for about another 30 mins...Help if you can! edit #2: maybe it is not getting power...3 wires, one green 2 white...and the green is getting power...but is one of the white suppose to get power? This post has been edited by snapshotgt: Feb 17, 2006 - 6:12 PM -------------------- Past: V6 Swapped 6G Celica, E46 BMW M3, Jeep Wrangler TJ
Current: 850rwhp C6 Corvette Grandsport, Gen1 6.2L Ford Raptor |
lol....6 hrs. later....no posts!
![]() If you know anything, please post! ![]() thanks, snapshotgt p.s. is this a fuse problem? (btw, i cannot find the fuse for it...but i have checked the fuses down of the left...) where is the fuse? -------------------- Past: V6 Swapped 6G Celica, E46 BMW M3, Jeep Wrangler TJ
![]() Enthusiast ![]() ![]() Joined Feb 3, '05 From USA/Virginia Currently Offline Reputation: 2 (100%) ![]() |
are the lights on and just not getting dimmed?
or are they not coming on at all? if it's the former i'd check the fuses, i guess. maybe check other lights: turn signals, high-beam, e-brake, door courtesy lights, and ignition light, maybe dome light too. see what they all do. |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 10, '03 From Wichita, KS Currently Offline Reputation: 5 (100%) ![]() |
Check the fuse labeled "7.5A Panel"
http://www.celicatech.com/vfewdsou/1995/95...ic/illumina.pdf -------------------- ![]() Project ST204.5 99.88946% complete... |
Well, all fuses are go...this is really weird.
The problem is, i cannot change the brightness of the gauges...(i.e. i cannot dim/brighten them)...but yes, the gauge lights work...just not the dimmer ![]() HeLp! snap -------------------- Past: V6 Swapped 6G Celica, E46 BMW M3, Jeep Wrangler TJ
Sounds like the "white green" wire going into the dimmer is grounding itself either in the dimmer switch or before. Also worth noting is the fact that LEDs won't dim the same way as incandescent bulbs do. They will dim slightly and then turn off once a certain voltage is reached. I'd suggest unpluging the dimmer and see if the lights stay on. If they do, you know that the white green wire is grounded somewhere before the dimmer. If they go off you know that it's a problem with the dimmer switch.
P.S. Did you get the LEDs I sent you? -------------------- ![]() Project ST204.5 99.88946% complete... |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 6, '05 From PA Currently Offline Reputation: 4 (100%) ![]() |
Wait, that car isn't in mint condition at all!!
lol I'm just busting your balls. Electrical problems are frustrating. My windshield wipers stayed on all the time so I had to pull the fuse. Turns out the switch went bad. Good luck man. -------------------- |
QUOTE(WannabeGT4 @ Feb 21, 2006 - 6:32 PM) [snapback]397343[/snapback] Sounds like the "white green" wire going into the dimmer is grounding itself either in the dimmer switch or before. Also worth noting is the fact that LEDs won't dim the same way as incandescent bulbs do. They will dim slightly and then turn off once a certain voltage is reached. I'd suggest unpluging the dimmer and see if the lights stay on. If they do, you know that the white green wire is grounded somewhere before the dimmer. If they go off you know that it's a problem with the dimmer switch. P.S. Did you get the LEDs I sent you? Okay. i'll try that.... yeah, i did get the LED you sent me...it worked perfect ![]() thanks. snap QUOTE(Cutrara @ Feb 21, 2006 - 8:07 PM) [snapback]397391[/snapback] Wait, that car isn't in mint condition at all!! These problem are b/c of me messing around that area...not the cars doing...lol....but yes, i hate electrical! snap -------------------- Past: V6 Swapped 6G Celica, E46 BMW M3, Jeep Wrangler TJ
Don't worry dude, it's all in good fun.
I messed a bunch of stuff up while diagnosing an electrical problem. You're not the only one lol ![]() This post has been edited by Cutrara: Feb 21, 2006 - 8:43 PM -------------------- |
Just looking over this again and thought I'd clarify something. If ANY of the "white green" wires in the wiring diagram I posted are grounded it could cause the dimmer to stop functioning since electricity takes the path of least resistance. So if it still works after you unplug the dimmer it could be any of the "white green" wires you see in the wiring diagram or in J/B NO.3.
Did you figure it out yet?
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Jul 11, '06 From Sefner, FL Currently Offline Reputation: 24 (100%) ![]() |
i know i'm bringing this old thread to life but i'm having the same problem snaps had, i'm going to try tonight with the dimmer unplugged
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 29, '02 From Franklin/Nashville, TN Currently Offline Reputation: 16 (100%) ![]() |
QUOTE(illneversellmycelli @ Aug 15, 2006 - 4:15 PM) [snapback]469328[/snapback] i know i'm bringing this old thread to life but i'm having the same problem snaps had, i'm going to try tonight with the dimmer unplugged if the dimmer knob is unplugged, then no lights will work. -------------------- |
Lo-Fi Version | Time is now: February 23rd, 2025 - 8:14 AM |
