What tires do you have? |
Feb 18, 2006 - 12:13 PM |
Enthusiast Joined Dec 29, '05 From So-Cal Currently Offline Reputation: 12 (100%) |
215/45/17
This post has been edited by chacha: Feb 18, 2006 - 12:15 PM |
Mar 7, 2006 - 3:55 PM |
Enthusiast Joined Aug 18, '04 From Silverdale, WA Currently Offline Reputation: 0 (0%) |
Just to update this I decided to get Falken Ziex 512's. I just got them installed yesterday and they are a lot quieter than the Yokohamas that were on it before. Also they grip better but that could also be because the others were almost bald.
Mar 7, 2006 - 8:43 PM |
Enthusiast Joined Jun 14, '05 Currently Offline Reputation: 1 (100%) |
anyone ever tried or seen some Celica GTS wheels (or any 16in wheels in the matter) mounted on 205/55/16?
I have a set of 205/55 mounted on some Solara rims right now, but since I cant use then on my Celica I'll just get some 16in wheels and mount then on.. |
Mar 7, 2006 - 8:46 PM |
QUOTE(jdg371 @ Mar 8, 2006 - 1:43 AM) [snapback]404206[/snapback] anyone ever tried or seen some Celica GTS wheels (or any 16in wheels in the matter) mounted on 205/55/16? I have a set of 205/55 mounted on some Solara rims right now, but since I cant use then on my Celica I'll just get some 16in wheels and mount then on.. That is what mine are. They look a lot better than the cheap stock steel ones that were on it. Plus the GTS rims are wider. |
Mar 8, 2006 - 7:27 PM |
QUOTE(bindertch @ Mar 7, 2006 - 8:46 PM) [snapback]404211[/snapback] QUOTE(jdg371 @ Mar 8, 2006 - 1:43 AM) [snapback]404206[/snapback] anyone ever tried or seen some Celica GTS wheels (or any 16in wheels in the matter) mounted on 205/55/16? I have a set of 205/55 mounted on some Solara rims right now, but since I cant use then on my Celica I'll just get some 16in wheels and mount then on.. That is what mine are. They look a lot better than the cheap stock steel ones that were on it. Plus the GTS rims are wider. You have the same size tire? |
Mar 8, 2006 - 7:41 PM |
No mine are 205/50/16. I was told that the 55 size would make the sidewalls weak for cornering. Even now I have noticed that the car has kind of a floating feeling in the rear. I am going to check the pressures and make sure they are right though.
Mar 8, 2006 - 10:45 PM |
215/45/17 Sumitumos HTRZII
oops lol 215 not 245 lol. wow. This post has been edited by x_itchy_b_x: Mar 9, 2006 - 12:23 AM -------------------- |
Mar 8, 2006 - 11:17 PM |
QUOTE(x_itchy_b_x @ Mar 8, 2006 - 10:45 PM) [snapback]404899[/snapback] 245/45/17 Sumitumos HTRZII how the hell did you fit those on your car without rubbing? -------------------- 15PSI - 30MPG - Megasquirt Tuned
Mar 9, 2006 - 12:01 AM |
Enthusiast Joined Aug 31, '02 From Virginia Currently Offline Reputation: 4 (100%) |
Dunlop SP Sport 5000s
Mar 9, 2006 - 8:00 AM |
Enthusiast Joined Jul 10, '05 From Monroe, WA Currently Offline Reputation: 6 (100%) |
celicazr, do your tires make LOTS of noise loosing traction? i tried some azenis on an ae86 and didnt like the noise when it went sideways.... YUCKY but very sticky for normal driving it felt like i was taking a corner in a go kart the way it took that turn so tight.
-------------------- 94' ST Coupe - 5sfe Motor swap and brake swap.
Mar 9, 2006 - 8:48 AM |
Enthusiast Joined Feb 3, '06 From Czech Republic (Europe) Currently Offline Reputation: 56 (100%) |
205/50/16 Michelin MXM HX (http://michelinman.com/catalog/tires/MichelinPilotMXM.html?tiretype=3&tire=8)
-------------------- No more replicas... This is evolution... This is SS-four :)
________[Featured Celica of 6gc.net @ 2010]_________ |
Mar 9, 2006 - 9:20 AM |
Enthusiast Joined Mar 25, '05 From Sydney, Australia Currently Offline Reputation: 0 (0%) |
QUOTE(celicast3sgte @ Mar 10, 2006 - 12:00 AM) [snapback]405031[/snapback] celicazr, do your tires make LOTS of noise loosing traction? i tried some azenis on an ae86 and didnt like the noise when it went sideways.... YUCKY but very sticky for normal driving it felt like i was taking a corner in a go kart the way it took that turn so tight. Which Azenis did you use? I dont think you would've use the rt215 or the rt615. These are more for track days and twisties. Man they are expensive just for 205/50/15 and tires wear is very quick(I've been told your lucky to get 20,000Kms out of them). These tires will be begging you to push your car harder around corners. Once they are warmed up they will stick like crazy -------------------- 98 ST204 ZR - Black Beauty - Roaming the streets of Sydney 73 TA22 LT - Tiffany Blue - Mint Classic Weekend Cruiser 75 TA22 LT - Snow White - Mint Classic Weekend Cruiser 77 RA28 LT - Flubber Green - Mint Classic Weekend Cruiser 94 MX-5 NA8 Clubman - Red Racer - Looking for corners WIP Project: 69 RT40 Corona, 2nd WIP Project: 66 RT40 1600s Corona 86 Corona RT142 - Daily Driver 6GC 4 Life Baby!!! |
Mar 9, 2006 - 3:07 PM |
Enthusiast Joined Apr 14, '03 From Long Island, N.Y. Currently Offline Reputation: 1 (100%) |
Falken for life
Mar 9, 2006 - 7:12 PM |
14in unkown tires<< the ones on the Celi
205/55/16 Goodyear Eagle << soon to be mounted when I get some GTS wheels |
Mar 10, 2006 - 7:33 AM |
Enthusiast Joined Nov 21, '05 From Australia, Melb Currently Offline Reputation: 0 (0%) |
225/40/R18
i use continental typres.... have anyone heard of them? apparently they're made in japan i pop one of the tyre and wanna get a replacement, it costed me AU$450 per tyre so i end up replacing it with falcon which was AU$220 if someone have heard of it.. tell me why are they so expensive! i hate them.. theyre slippery NaKeD -------------------- |
Mar 10, 2006 - 9:00 AM |
Enthusiast Joined Aug 30, '02 From Michigan Currently Offline Reputation: 0 (0%) |
Continental is actually a German company, I interviewed with them not long ago.
Tires I'm using/ Previously used: Comp Tires: Hoosier AS04/AS03 - you pay for traction, not longevity... the best there is for autocross, but dont expect to get more than a 1/2 a season on them if you race frequently, if you only do a few you might stretch them a full season. Front: 205/55/14 Rear: 225/55/14 MR2na Kumho V710s - just purchased, havent ran on yet. I hear they are comparable to the hoosiers (slightly less sticky) but last over 2X as long... these are the perfect tires for the budget autoxer, if you are a newbie autoxer and looking to save even more money than go with the Victoracer, these are a few steps up from the victos. Front: 205/55/14 Rear: 225/55/14 MR2na Kumho VictoRacer - Used these on my friends GS classed Saturn SC2, great great budget autox tire, versitle and can be used in the wet too. perfect for beginners and you can get over 2 seasons on them. 205/55/15 all around Saturn SC2 Comp. Street Class Tires: Falken Azenis RT-615 - Only used them for a very limited ammount of time, head and shoulders better than your standard high performance street tire, handles the wet MUCH better than the previous RT-215s, but they seem to have lost a little of the dry traction, however still much better than the comparable yokos or toyos. They just need to start making more sizes of these. 205/40/16 all around MR2t Hankook Ventus Z-212 - Just purchased and putting a few miles on them right now. These are what I plan on running this year for any bad weather events or events where i dont want to take the R-compounds. From what I have heard is these tires are excellent for heavier cars (EVO, WRX, STI, etc..) or cars with big wheels. The sidewalls are a little soft compared to the azenis so you have to keep them pumped to get the best traction. Overall I am happy with them so far, a little messing around in an abandoned parking lot proved what i had heard about the sidewalls, as i would take sharp turns and quick switchbacks it tended to understeer more than the azenis did, roll over was more than falkens but nothing to be worried about. after putting some more air in the tires the car became a little more neutral, though it still errored on the side of understeering. These also have GREAT wet traction for a street comp tire. 195/60/14 all around (width seems under rated, side by side with my Kumho 711s these look wider) MR2na High Performance Street Tires: Yoko AVS ES100 - Good performance street tire, a little better life expectancy than the Comp street tires, but not quite in the same class as the Kooks or the Falkens though... not a tire for someone who wants to be competitive in a street tire class, but works great if you just want to go to have fun. 205/45/16 all around MR2t Kumho Ecsta Supra 712 - Great cheap tire if you get a package deal on some wheels/tires, I've had a set that has lasted me 3 season of summer driving + they have 4 autox events on them, one got a bubble in the sidewall last summer so I am going to take it to discount tire to get it replaced, they look like they still have another season or 2 on them. 205/40/17 97 Celica ST / 2000 Celica GTS All Seasons: Continental ContiSports - average all season tire, has real soft sidewalls and great traction in snow and rain, actually pretty decent in icey conditions as well. Poor traction in dry however. These are the tires that came on my Cobalt. 195/60/15 Cobalt Kumho Ecsta 711s - i really like these for all seasons, very cheap, good treadlife and good wet traction for just driving around, no complaints. Front: 205/55/15 Rear: 225/55/15 MR2na -------------------- Believer, you'll leave her, in leaving them all No but I don't buy it Like anything you do, as anyone you are Cause I'm... Ten Speed, of God's Blood & Burial |
Mar 10, 2006 - 4:18 PM |
Enthusiast Joined Mar 17, '05 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) |
I run DOT approved road legal slicks full time. Toyo Proxes RA1
write up The tread pattern may not look very exciting, but these tyres are awesome. Once you get some heat into them it is nigh on impossible to break traction when driving on public roads. Better still is the wet weather capability. These tyres are as good in the wet as a lot of high performance tyres are in the dry. And the wear rate is pretty impressive too. Gary -------------------- 1994 ST205 Celica GT-FOUR Group A WRC - running in new engine 1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come.... GT-Four spec list |
Mar 11, 2006 - 9:35 AM |
Enthusiast Joined Dec 16, '02 From New York Currently Offline Reputation: 4 (100%) |
I'm actually leaving to get new tires, so i will let you know what i get... cause apparently ignoring your allignment problem for long enough results in this:
yes i know, i'm a moron, iiii don't wanna hear it. -------------------- Buy my Celica $2,500 - http://www.6gc.net/forums/index.php?showtopic=76562&st=0
Mar 11, 2006 - 9:40 AM |
QUOTE(boosted_K2 @ Mar 10, 2006 - 9:00 AM) [snapback]405589[/snapback] Continental is actually a German company, I interviewed with them not long ago. Thanks dude for clearing that up.. wonder why they cost more than others IMO they're not that good NaKeD -------------------- |
Mar 11, 2006 - 9:48 AM |
Enthusiast Joined Mar 17, '05 From The Netherlands Currently Offline Reputation: 0 (0%) |
Currently:
Avon ZZ3 215-45-17 : Overall a good tyre but tricky when in the rain. Have driven a Celica with 215-45-17 Goodyear Eagles GSD3 tyre. Those are on of the best tyres made for our cars. But since i am getting new (18"rims) with the rim deal i got: Toyo Proxes T1-R 225-40-18: Great on dry, can be tricky in wet. Seem te wear out fast. This al on experience from other! -------------------- JDM Powerplant installed, BPU coming very soon!
Lo-Fi Version | Time is now: January 9th, 2025 - 10:43 AM |
