Enthusiast ![]() Joined Sep 14, '04 From Germany Currently Offline Reputation: 0 (0%) ![]() |
Cause the 9006 bulbs don't fit anymore. How did you convert it to H1???
cut the 9006 plug off, and solder in a H3 plug, which works for the H1 bulb.
does the high beams still use 9004? or is it h1 too?
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Nov 22, '03 From Tracadie-Sheila, NB (Canada) Currently Offline Reputation: 14 (100%) ![]() |
highs stay what there were
How did you solve the problem?
QUOTE(drhossa @ Feb 21, 2006 - 6:44 AM) [snapback]397127[/snapback] How did you solve the problem? solve what problem? the high beams use the old bulbs, the lows get a H3 connector, with a H1 bulb. the "marker" lights use a 194 socket and bulb. i spliced into my sidemarkers for power for them. -------------------- Former Team 5SFTE pro member ;)
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 17, '03 From Bloomington, Indiana Currently Offline Reputation: 62 (98%) ![]() |
QUOTE(TurbO @ Feb 18, 2006 - 2:23 PM) [snapback]395838[/snapback] does the high beams still use 9004? or is it h1 too? highs use 9005 -------------------- ![]() |
Lo-Fi Version | Time is now: February 23rd, 2025 - 2:19 PM |
