![]() Enthusiast ![]() ![]() ![]() ![]() Joined Apr 15, '03 From San Jose, CA, USA Currently Offline Reputation: 1 (100%) ![]() |
well the post title pretty much sums it up. I would like to paint the airbag pannel on the passenger side but was scared to pull it off thinking the airbag might deploy.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 12, '02 From Webster Ma. Currently Offline Reputation: 1 (100%) ![]() |
i got my gt-four model from e-bay
Enthusiast ![]() Joined Mar 24, '03 From virginia Currently Offline Reputation: 0 (0%) ![]() |
Whoa! before you go yanking that **** off, disconnect you're battery, and wait like 5 mins. the bag shouldn't deploy, but there's a safety relay that takes several mins. to shut down, then go pulling a jerking all you want, found the info trying to change out steering wheels, and getting around the driver's bag, in case your wondering!
![]() Enthusiast Joined Dec 23, '02 From Joplin, Missouri Currently Offline Reputation: 0 (0%) ![]() |
The air bag hasn't deployed on me yet i have my cover to where i can lift the front side for extra storage area.
![]() Administrator ![]() ![]() ![]() ![]() ![]() Joined Aug 23, '02 From Seattle, WA Currently Offline Reputation: 14 (100%) ![]() |
Wait, so you store stuff in the air bag compartment? If so, that could easily kill your passenger if you got in even a minor fenderbender. -------------------- New Toyota project coming soon...
Enthusiast ![]() Joined Nov 18, '02 Currently Offline Reputation: 0 (0%) ![]() |
to discharge the air bags you have to disconnect the battery for not less than 90 seconds. After that you can do whatever you want with them. If you want to take the whole air bag out, you going to have to take the whole dash board off. I've dane it on my car.
good luck. |
also, i dont know about any extra storage room under the airbag cover. there is an actual airbag sits, there is no spase at all.
Enthusiast ![]() ![]() ![]() Joined Oct 1, '02 From North Bethesda, MD Currently Offline Reputation: 0 (0%) ![]() |
that's not the panel, it's the airbag. just be aware. and also, it's vinyl, not plastic, so if you paint it, use vinyl dye otherwise it will look like crap. -------------------- 1994 Lexus ES300
1989 Supra Turbo 1990 RHD ST185RC - JDM Spec |
Ok heres the deal when i got my body kit put on the front sensor for the air bags was removed and the unit did not all of a sudden shoot out or the light stay on all the time. So i removed the brain for the air bags and left the harness for now as far as the passenger air bag i completely removed it from the car (about 10#'s lighter) and i have no problems with the drivers side either.
I did however keep the cover for the passenger side and i remounted the cover itself and mounted a 7.2 lcd on the bottom of it and its a great spot for a tv. |
Lo-Fi Version | Time is now: February 18th, 2025 - 4:29 PM |
