> direct injector fit from 7mgte to 7afe???
post Feb 19, 2006 - 12:33 AM
southwest2118
Joined Jan 13, '06
Will 7mgte injectors fit the 7afe? with out mods? or
This post has been edited by southwest2118: Feb 21, 2006 - 4:27 PM
post Feb 21, 2006 - 4:21 PM
southwest2118
Joined Jan 13, '06
BUMP
will it fit?? help me out guys.. would I have to do any mods? would 440cc be too much for safc or safc2 to drop?
post Feb 21, 2006 - 4:28 PM
i dont think they will work.
i believe the TE's injectors are low impedance.
also 440cc is gonna be on the big side for your application.
This post has been edited by presure2: Feb 21, 2006 - 4:28 PM
post Feb 21, 2006 - 5:53 PM
southwest2118
Joined Jan 13, '06
what would fit well and is high impedance?
and what size would be pretty good? like do hondas fit ours?
post Feb 21, 2006 - 9:22 PM
frotou
Joined Jan 9, '04
From Quebec city, Quebec, Canada
24lbs injectors from 3sge/5sfe , 30lbs injectors from turbo mazda mx6/ford probe (89-92), 88-92 injectors from 7mge (n/A), 36 lbs injectors from mr2 4agze (87-89)
claude
post Feb 21, 2006 - 10:17 PM
southwest2118
Joined Jan 13, '06
QUOTE(frotou @ Feb 21, 2006 - 8:22 PM) [snapback]397431[/snapback]
claude
will these work or how about these it will fit with no problem?
what is the stock 7afe injector size?
This post has been edited by southwest2118: Feb 21, 2006 - 10:23 PM
post Feb 22, 2006 - 7:54 AM
yea, i was thinking for a 7a, somthing in the 360cc range should be more than adequate.
what id REALLY like to see is someone try the 2bar map/ bigger injector setup like us 5s guys do.
the map from both are identical, so in theory, the 2bar from the alltrac or mr2 would work.
that, and the SAFCII or better yet the emanage or SMT6.
post Feb 22, 2006 - 8:20 AM
southwest2118
Joined Jan 13, '06
what year range alltrac or mr2?
post Feb 22, 2006 - 12:00 PM
90-93 alltrac mkII mr2
post Feb 26, 2006 - 4:04 AM
southwest2118
Joined Jan 13, '06
QUOTE(presure2 @ Feb 22, 2006 - 11:00 AM) [snapback]397791[/snapback]
will non turbo 210CC mr2 yellow top work on my 7afe?
what size is stock?
post Feb 26, 2006 - 4:10 AM
StreetRacing10PS...
Joined Oct 10, '04
From New Jersey
210CC is a little small if your going forced induction.
post Feb 27, 2006 - 8:27 PM
southwest2118
Joined Jan 13, '06
any body know if Toyota yellow top 305cc injectors are high impedance?
money is kinda tyte so i think i'ma go with the walbro and fmu for now.
This post has been edited by southwest2118: Feb 28, 2006 - 1:31 AM
post Feb 28, 2006 - 8:08 AM
OOBE
Joined Aug 30, '02
From San Juan, PR
turbo mazda mx6/ford probe (89-92), <----------This is what I am currently running with no problems whatsoever. Running 10 PSI and it can take 12 with a good tune.
Don't get an FMU, man...it's not safe to push the stock injectors. I did that for a while with the stock pump and she burped sometimes. I think that's how I broke my #3 piston. Get the same injectors I got, a AFPR and a $90 Walbro 255LPH fuel pump (extremepsi.com) and you'll have plenty of fuel for a while for very cheap.
post Feb 28, 2006 - 12:00 PM
i agree with that 100%
post Feb 28, 2006 - 7:36 PM
southwest2118
Joined Jan 13, '06
with those turbo probe injectors can i use a safc 1 ? the one with the five knobs..it only adusts to +/- 30% right?
i know safc2 looks nice and all but.. is the hi low throttle, knock counter, and what else? worth $150 more?
post Feb 28, 2006 - 7:45 PM
southwest2118
Joined Jan 13, '06
What about those yellow injectors?
post Mar 3, 2006 - 12:24 AM
southwest2118
Joined Jan 13, '06
i think off the 7mge?
think it will fit?
post Mar 3, 2006 - 11:03 AM
OOBE
Joined Aug 30, '02
From San Juan, PR
QUOTE(southwest2118 @ Feb 28, 2006 - 5:45 PM) [snapback]401088[/snapback]
I use the 2nd gen S-AFC...not the latest one...the regular one with the blue display. It works great. You can use the older style one with the knobs but it's not that adjustable.
post Mar 11, 2006 - 2:28 AM
southwest2118
Joined Jan 13, '06
QUOTE(southwest2118 @ Mar 2, 2006 - 11:24 PM) [snapback]402049[/snapback]
think it will fit?
??? part number is 23250-70040.
This site says one thing and one says another?
help me out guys
if i had the green ones they would have fit my harness but the red line shows where the slots are on the yellow ones i chopped them off and fit nicely. wink.gif
This post has been edited by southwest2118: Mar 11, 2006 - 2:59 AM
post Mar 11, 2006 - 8:32 AM
QUOTE(southwest2118 @ Mar 11, 2006 - 2:28 AM) [snapback]405983[/snapback]
think it will fit?
help me out guys
i dont know the answer, but you can find out the impedance easily enough with a multimeter.
just set it to read ohms, and if it reads 2-4ohms, theyre low, and if its 12-16 theyre high. wink.gif
Lo-Fi Version Time is now: February 25th, 2025 - 4:42 PM
