2 Pages V  < 1 2
> direct injector fit from 7mgte to 7afe???
post Mar 11, 2006 - 11:28 AM
southwest2118
Joined Jan 13, '06
it reads like 3 on all ......**** i already tryed them once what do you think happens when the wrong impendence is used?
post Mar 11, 2006 - 11:47 AM
QUOTE(southwest2118 @ Mar 11, 2006 - 11:28 AM) [snapback]406065[/snapback]
the injectors wont work. lol
post Mar 11, 2006 - 12:40 PM
southwest2118
Joined Jan 13, '06
well i thought they were high ...so i put them in and it ran ....rich...but it ran/??? no abnormal signs?
post Mar 14, 2006 - 2:40 AM
southwest2118
Joined Jan 13, '06
ok this says they are high
when i put them in it was not plug and play.. i had to shave the guides on the side...mine are lower so dose that mean low or high?
post Mar 14, 2006 - 12:45 PM
OOBE
Joined Aug 30, '02
From San Juan, PR
QUOTE(southwest2118 @ Mar 11, 2006 - 10:40 AM) [snapback]406086[/snapback]
If they're the wrong ones, the injectors will not work, like Big P said. tongue.gif
You're running rich because you need an AFPR and an S-AFC to control the fuel. When I put my MX-6 injectors, the car didn't even start at first...eventually it did but burping like crazy and shooting flames when I accelerated it high in the RPMs. I had to close the AFPR, set the S-AFC graph all to -50 and start tweaking away until it ran right. IT was so funny. We got out of there covered in black soot and with teary eyes and runny noses. laugh.gif
I forgot, I had to cut my stock harnesses and use the Mazda ones that came with the injectors.
post Mar 14, 2006 - 11:47 PM
southwest2118
Joined Jan 13, '06
the stock red injectors read like 13ohm so i went to radio shack and bought some resisters 10ohm 10w and put the in line with each injector...i think it made a differance?
I dont have a FPR right now just running safc and the 300cc plus or minus like five. i have safc turned down -30 all across. but i think i'm still running very rich....can't tell but i think because theres about a 60% differance between the red and yellow. waiting for somebody to tell me i can use thier dyno...
post Mar 15, 2006 - 12:00 PM
i think if you were to install the 2bar map, it would lean things out ALOT, and you wouldnt need as much correction with the SAFC.
post Mar 15, 2006 - 12:51 PM
southwest2118
Joined Jan 13, '06
what car should i take it out of?
also is it just connecting the vac line and the wires or do i have to adjust the safc frist gen again? to set it for that car the map came off of? cars at the shop right now thier puting in the down pipe and muffler. i'm kinda worried the tip will scrach every bump ? the car is lowered like 3in all around ..also the muffler has a 4" tip ....i was thinking about painting it black to kill that street racer look.
2 Pages V  < 1 2
Lo-Fi Version Time is now: February 25th, 2025 - 4:25 PM
