wierd shifting in first |
Feb 19, 2006 - 6:21 PM |
Enthusiast Joined Sep 6, '04 From oakdale Mn Currently Offline Reputation: 0 (0%) |
I just put in a new 5sfe cuz I spun a bearing in my old one. when i grab the shifter it has trouble going back to center to neutral. when i put the shifter left to right it seems like it is catching on something on the housing but there is nothing there catching it. when the shift cables were unhooked from the tranny the shifter was perfect. what do you think seems to be the problem? i think i might be a half quart low on mtf would it make that much of a diff? thanks guys.
This post has been edited by rjbibeau: Feb 19, 2006 - 6:21 PM -------------------- |
Feb 19, 2006 - 9:17 PM |
Enthusiast Joined Mar 23, '05 From Kansas City Currently Offline Reputation: 0 (0%) |
QUOTE(rjbibeau @ Feb 19, 2006 - 5:21 PM) [snapback]396295[/snapback] I just put in a new 5sfe cuz I spun a bearing in my old one. when i grab the shifter it has trouble going back to center to neutral. when i put the shifter left to right it seems like it is catching on something on the housing but there is nothing there catching it. when the shift cables were unhooked from the tranny the shifter was perfect. what do you think seems to be the problem? i think i might be a half quart low on mtf would it make that much of a diff? thanks guys. the fluid could make a difference yes. top it off first thing then try again -------------------- 1999 Celica GT
Feb 20, 2006 - 3:12 PM |
fluid is topped off. it seems to be a problem with the shifter housing. like when i go into first it is actually going into third. for me to go into first i have to hold it in place at first.
Feb 21, 2006 - 3:43 PM |
bump. anyone got any ideas?
Feb 21, 2006 - 4:05 PM |
did you bleed the clutch lines? did you fill the tranny with oil?
it kind of sounds like you put your shifter cables on the wrong way one the tranny. This post has been edited by lagos: Feb 21, 2006 - 4:06 PM -------------------- 15PSI - 30MPG - Megasquirt Tuned
Feb 23, 2006 - 9:40 PM |
i have all the other gears. shifts into reverse nicely. but if that is the case i would feel like a dumb azz haha. but ya i did everything that you mentioned.
Feb 26, 2006 - 1:31 PM |
Enthusiast Joined Feb 16, '05 From Brantford, Ontario, Canada Currently Offline Reputation: 0 (0%) |
is the actual shifter catching on anything?
Lo-Fi Version | Time is now: November 28th, 2024 - 12:41 AM |
