car troubles |
car troubles |
Dec 16, 2002 - 9:34 PM |
Enthusiast Joined Dec 16, '02 From Home, P*town Currently Offline Reputation: 0 (0%) |
alright, problem w/ my car. One of the hooks holding my battery on the mount snapped and my battery fell in the engine leaning up against one of the tubes. It did it when I first had the car, but I put it on and it hadn't done it since. So my car had two power surges as I was turning into my street and then when I turned it off, I couldn't turn it back on. (this was before I found out the battery fell) All the wires look fine and all the connections are fine and the fuses are all good. I haven't figured out how to check the relays and I don't see how it could be the starter because the starter is on the other side and under (pretty much) the engine. So does anyone have any suggestions for what the problem could possibly be?
Dec 16, 2002 - 11:43 PM |
something like that happened to me not to long ago. check the wires that hook up to the battery again. if you still can't find anything wrong with them, then try a new battery.
Lo-Fi Version | Time is now: November 23rd, 2024 - 10:42 PM |
