rear speakers 98 convertible, How to access rear speakers |
Feb 23, 2006 - 5:40 AM |
Enthusiast Joined Feb 16, '06 From Philadelphia Currently Offline Reputation: 0 (0%) |
I am getting ready to install new speakers in the rear panels of my car (98 covertible). I cannot for the life of me figure out how to get the side panels off that cover the speakers. Does anyone have any ideas or suggestions. Do I have to take the seats out? I can only find one screw near the seatbelt harness but I can't believe that just one screw holds that entire cover in. Any assistance would be appreciated. Thanks
Feb 23, 2006 - 6:03 PM |
Enthusiast Joined Apr 19, '05 Currently Offline Reputation: 0 (0%) |
I ran into the same problem with my car when I was installing new rear speakers. You need to move the edge of the seat, where the seat cushion meets the plastic panel. Don't actually take off the seat cushion, just push the foam inwards towards the seat belt buckles, and you will see 2 or 3 plastic screws holding the side panel in (just like the plastic screws that hold the trunk inserts in). After you get those out, there are two visible screws near the rear windows. One has a snap on it. Take of both of these screws, then just wiggle the side panel out.
Feb 23, 2006 - 11:06 PM |
Enthusiast Joined Oct 5, '03 From South TX. Currently Offline Reputation: 14 (100%) |
u forgot the 2 screws at the bottom of the panel, which is why you atleast need to remove the lower portion of the seat
Feb 23, 2006 - 11:34 PM |
Enthusiast Joined Mar 19, '04 From Scottsdale, Az Currently Offline Reputation: 2 (100%) |
Your bottom seat pulls out. Top seat is bolted in from behind with (4) 13mm nuts. Panels have 4 screws. 2 on top and 2 on the bottom.
Feb 24, 2006 - 12:40 AM |
QUOTE(95celgt @ Feb 23, 2006 - 8:06 PM) [snapback]398734[/snapback] u forgot the 2 screws at the bottom of the panel, which is why you atleast need to remove the lower portion of the seat I installed rear speakers myself, and didn't need to remove any part of the seat. |
Feb 24, 2006 - 1:41 AM |
Enthusiast Joined Aug 18, '04 From NJ Currently Offline Reputation: 1 (100%) |
you dont need to take out the rear seat but it makes gives you more room to work.
Feb 24, 2006 - 11:03 AM |
QUOTE(95celgt @ Feb 23, 2006 - 11:06 PM) [snapback]398734[/snapback] u forgot the 2 screws at the bottom of the panel, which is why you atleast need to remove the lower portion of the seat Thanks any information about how to pull the rear seat out? I tried and there must be a trick to it because i can't get it to budge |
Feb 24, 2006 - 11:18 AM |
the bottom piece just pull it straight up. dont be afraid to give it a good tug. the back piece unbolts.
Lo-Fi Version | Time is now: January 12th, 2025 - 6:32 PM |
