> 2425 lbs thats wat my title says....., So my car isn't so heavy after all
post Feb 23, 2006 - 12:25 PM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
So I got a renewal notice yesterday and It said on the tag that my car weighed 2425 lbs. That was quite weird cause I thought the celi's always weighed more than 2800 Lbs. Anyways, its all good.
post Feb 23, 2006 - 12:39 PM
95celgt
Joined Oct 5, '03
From South TX.
haha 2800? that the ballpark for my verts weight.
post Feb 23, 2006 - 12:56 PM
nik
Joined Sep 30, '02
i wish some one could go to an acurate scale a weight a celica
post Feb 23, 2006 - 1:13 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
I can go down to the Dump around by me. I can fill up, and get on the scale and weigh it. That should give us the full fluid weight of the Celica.
**** Photobucket
post Feb 23, 2006 - 1:18 PM
nik
Joined Sep 30, '02
QUOTE(95CelicaST @ Feb 23, 2006 - 12:13 PM) [snapback]398455[/snapback]
but how accurate are those scales?
post Feb 23, 2006 - 1:20 PM
95CelicaST
Joined Feb 5, '05
Well they weight you when you come in with all the junk you want to dump, and then weigh you when you leave, and the difference in weight is calculated into a price, and i'm sure they want to take you for every bit they can, so I am going to say they are pretty accurate.
**** Photobucket
post Feb 23, 2006 - 1:29 PM
Thats probably w/o a driver or any fluids.
post Feb 23, 2006 - 1:42 PM
nik
Joined Sep 30, '02
how much does a gallon of gas weigh?
post Feb 23, 2006 - 2:00 PM
Predator
Joined Feb 26, '05
From Sweden
0.7025 kg/litre
guess you want it in lbs/gallon or something....think that makes it 5.85 lbs/gallon not sure though, damn you and your imperial system wink.gif
post Feb 23, 2006 - 3:16 PM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
QUOTE(Predator @ Feb 23, 2006 - 2:00 PM) [snapback]398484[/snapback]
0.7025 kg/litre
I checked the math, it's right. Full tank of gas would accordingly wiegh 87.75lbs or around 40kg. Average person is about 75-80kg, or 165-176lbs. So a full tank and person only puts you up 120kg, or 263.75 lbs. That actually is a good bit of wieght in a small car.
Live Free, Be Happy
post Feb 23, 2006 - 3:31 PM
nik
Joined Sep 30, '02
5 quarts of oil
tranny fluid
grease
windsheild washer fluid
belts (is dry wieght with belts?)
side note:
also this is on stock wheel weight also probably 30 lbs each on st 14" 35 lbs on 15" gt
post Feb 23, 2006 - 3:37 PM
Zimluura
Joined Feb 3, '05
From USA/Virginia
haha, when i bought my car the title said 3700 lbs. i didn't do any research before taking it to dmv, so the new title says 3700 lbs. as well. i guess the last person just took a random stab at it.
post Feb 24, 2006 - 1:22 AM
CelicaZR
Joined Mar 25, '05
From Sydney, Australia
Gross vehicle Mass for the Celica here is 1600kg.
6GC 4 Life Baby!!!
post Feb 24, 2006 - 1:34 PM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
QUOTE(nik @ Feb 23, 2006 - 3:31 PM) [snapback]398511[/snapback]
5 quarts of oil
tranny fluid
grease
side note:
At first, I thought you were a bit off, but not after further thought. It's only about 4 quarts, at least on a 5sfe. There is right at 3 quarts of transmission fluid. The viscosity of oil and transmission fluid is about the same. You could round that to 2 gallons, so 11.7lbs if you use the same weight at fuel. I don't think petrol and oil weighs the same, but it's close. Also, the 3 quarts is more a manual 5s transmission. It probably is 5 quarts for a auto. But the auto weighs more due to mechanics too, so that all the more weight. Add another gallon for miscellaneous fluid; you've got another 5.85 pounds. Total is 105.3lbs of liquid in the car. I think the stock wheel is only 16-17lbs. But the tire would put it up to 30lbs. I think the wheel and tire would be considered in the dry weight of the vehicle. I think belts would be considered too, and if not, they only weigh a couple pounds all together max.
QUOTE(CelicaZR @ Feb 24, 2006 - 1:22 AM) [snapback]398799[/snapback]
That has to be for the gt-4, and even then, that's high. That's about 3520lbs. That's working on big sedan wieght. I didn't think the Celica was real small, but it's not big. I would guess something like 2800-2900lbs for mine. But I'm just pulling that number out of the air.
Live Free, Be Happy
post Feb 24, 2006 - 3:48 PM
I'll go weigh my car on the truck scale around here tonight. It's accurate to 20 lbs.
post Feb 24, 2006 - 3:55 PM
nik
Joined Sep 30, '02
QUOTE(Coomer @ Feb 24, 2006 - 2:48 PM) [snapback]399142[/snapback]
thanks coomer
post Feb 24, 2006 - 5:48 PM
CelicaZR
Joined Mar 25, '05
QUOTE(Bigmeanbulldog55 @ Feb 25, 2006 - 5:34 AM) [snapback]399065[/snapback]
Note I said Gross Vehicle Mass.
The Nominal kerb mass for
SX Manual - 1165kg
SX Auto - 1195kg
ZR Manual - 1178kg
ZR Auto - 1208kg
6GC 4 Life Baby!!!
post Feb 24, 2006 - 10:04 PM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
QUOTE(CelicaZR @ Feb 24, 2006 - 5:48 PM) [snapback]399201[/snapback]
SX Manual - 1165kg
SX Auto - 1195kg
ZR Manual - 1178kg
ZR Auto - 1208kg
I'm not saying that you are lieing. I believe it says that. I just think it's a high number, and it's hard to believe.
Live Free, Be Happy
post Feb 24, 2006 - 10:09 PM
trd94
Joined Jan 9, '05
From green springs ohio
my celica came in at 2600 lbs and that is with all the audio in it ( 2 -12" kickers 1 3.0 farad cap,1-4 channel 800 watt amp, speaker boxes,and all the wiring,). i weighed my car at the local grain elevator scales and had them zero it out and check the calibration wink.gif . but my car is a st rolleyes.gif
post Feb 25, 2006 - 2:03 AM
lumbercis
Joined Jan 28, '06
From Washington, DC
Why is everyone always trying make these cars heavier than they are? Say it with me now, "CELICAS ARE LIGHT CARS!" They're lighter than an Integra, 240SX, Eclipse, etc. and even comparable to some of the heavier trim levels of Civic. Check here: http://autos.msn.com/home/used_research.as...=Home&pos=used1
The only heavy celica is the GT-4 which is somewhere around 3200lbs because of the AWD drivetrain. I think the perception of celicas as heavy comes from the fact that in the US, you are working with the 5sfe at best, which makes it feel heavier than it is.
Drop a Beams into your "heavy" celica and you will have similar power to weight as an Integra Type R (and only because the Type R is lightened from the factory, Otherwise the celica would own it.) Drop a 3sgte in there and you have the potential to make a fool out of anything on the streets.
So, PLEASE, stop with the "my celica is heavy" stuff. It just ain't true.
J.
This post has been edited by lumbercis: Feb 25, 2006 - 2:04 AM
Lo-Fi Version Time is now: February 17th, 2025 - 12:59 AM
