> Pcv Valve, I broke it
post Feb 23, 2006 - 5:39 PM
Dunners
Joined Oct 25, '05
From Brisbane, Australia
Hey guy's,
I was just replacing my valve cover gasket and when i took the hose off the pcv valve that runs to the intake manifold the stupid thing broke. Just wondering what exactly the pcv does and how hard is it to get hold of another one. Also where are the injectors. cheers for your help.
post Feb 23, 2006 - 7:42 PM
Dunners
Joined Oct 25, '05
Hey guy's,
Just finished putting the new gasket on, This is the first gasket i've done. Is there usually a bit of a burning smell? It's definetely not oil, i thought it might just be the new gasket. I just superglued the pcv valve back together and silicone'd it up. It hasne't broken yet. haha. Also when i turned the car back on there was some clear fluid running down the out side of my exhaust after the cat, i didn't have the a/c on and i have no idea where it's coming from. any idea's. cheers
post Feb 23, 2006 - 7:55 PM
The PCV (Positive Crankcase Ventilation) basically sucks out any excess gases and oil mist out of the crankcase so you get better combusion. I sure hope none of that glue gets into your crankcase.
post Feb 23, 2006 - 8:06 PM
Dunners
Joined Oct 25, '05
She'll be right, I took the valve out of the valve cover when it was out of the car and glued and let it dry before i put it back in.thanks for the reply
post Feb 23, 2006 - 8:10 PM
Yeah I'm just thinking that the engine gets pretty hot and hot enough to melt glue. On my hood scoop the mesh was glued to the fiberglass and due to the heat (granted i have a 3s its a bit hotter) the glue began to drip on my heat shield.
post Feb 24, 2006 - 1:30 AM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
I think its like a $1 or 2.. I got mine from advance auto parts.. easy to replaced and cheap.
post Feb 24, 2006 - 3:36 AM
Hanyo
Joined Aug 16, '03
From Bay area
do you need a pvc valve if your using a breather filter?
post Feb 24, 2006 - 9:34 AM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
QUOTE(Hanyo @ Feb 24, 2006 - 3:36 AM) [snapback]398847[/snapback]
It's easier to use one, otherwise your vacum system gets to acting funny. I broke mine changing my valve cover gasket, and the idiol went high on me.
Live Free, Be Happy
post Feb 24, 2006 - 3:05 PM
Jeremy1210
Joined Dec 16, '02
From Cincinnati, Ohio
just get a new one. They are like 4$
Lo-Fi Version Time is now: January 11th, 2025 - 8:04 PM
