wiring and sizing |
wiring and sizing |
Feb 23, 2006 - 11:37 PM |
ok for wiring harness (body and engine) wat gauge wire should i use?
and for things like normal speakers, neons, gauges, ect.. what should i use |
Feb 25, 2006 - 10:35 AM |
Enthusiast Joined Jan 22, '04 From WA, Australia Currently Offline Reputation: 1 (100%) |
Neons draw very minimal current.. So anything is really fine, 16Ga or something simlar. The same thing with speakers, 14-16Ga will be fine. You may want to run 12Ga, but I don't really see the advantage, other than less resistance, and *maybe* better SQ. Subs I run 10Ga, to be safe.
Obviously for running power/ground cable to amps, you need much thicker cable. Up to around 1000W rms, you'd be fine with 4Ga cable. Engine wires, I wouldnt have the slightest. This post has been edited by ShadowFX: Feb 25, 2006 - 10:40 AM |
Feb 25, 2006 - 11:37 AM |
I'd replicate the wire sizing that Toyota uses from the factory for the body/engine harness.
Feb 27, 2006 - 7:29 PM |
Enthusiast Joined May 5, '05 From New-Brunswick Canada Currently Offline Reputation: 3 (100%) |
-------------------- ----------------------6GC's FIRST V6----------------------
JDM 96 MR2-T Faster - 94 Celica GT 3MZFE Funner - 99 Rav 4 AWD Handy |
Lo-Fi Version | Time is now: November 27th, 2024 - 8:41 PM |
