> Interior lights help?
post Feb 25, 2006 - 5:03 PM
bdog_v
Joined Jan 17, '06
From Wisconsin
Hello I am trying to replace my cigarette lighter light that is burned out it is supposed to be green in color as it has a "green condom" on it. I would like to go blue in color so my question is
-This bulb is designed very odly it does not slide into the holder it is sodered to 2 metal posts that slide into the holder. So is there a replacement that is the same or should I buy a standard #74 bulb and glue it in and run the wires to hook it up? I think that would work correct???
-My other problem is that I don't know where I can buy a little blue condom for these #74 bulbs so they won't be green anymore?
-Or do you guys just by little blue Leds without a condom? Thanks.....
-Oh I'll be doing this on my ignition light and cigarette lighter......
post Feb 25, 2006 - 6:00 PM
snapshotgt
Joined Oct 12, '05
From Texas
I have done this with LEDs (ignition ring/cc unit/gauges/window switch...)
try to use LEDs, they'll come out brighter/better "true blue" than those plastic covers...trust me, tried way to many ways to make it look good wink.gif
~snap
post Feb 25, 2006 - 6:08 PM
Predator
Joined Feb 26, '05
From Sweden
it's a bitch to get a #74 to fit there but with a bit of modding it's def possible
post Feb 26, 2006 - 4:46 AM
94CELICAGT_98584
Joined Oct 27, '05
From Olympia, Washington
How do you get an LED to work? All I can find are like 4V Blue LED's..... Resistor? or what?
!!KANER!!
post Feb 26, 2006 - 5:50 AM
malpaso
Joined Feb 3, '06
From Czech Republic (Europe)
You have four choices:
- spray some color at that bulb
- use high illumination LED. There are two problems. First, you need to use resistor with LED, but there is no much place for this, second these LEDs are not "difusional", so it's difficult to do that...
- use LED with build in resistor. These LEDs are not high illumination -> weak light
- use another color of that "condom", but... Color with this rubber nonsences is horrible ("blue" is light-grey-blue and "red" rubber is more pink than red...)
post Nov 14, 2006 - 7:03 PM
BloodyStupidDave...
Joined Nov 14, '06
From Northampton, UK
QUOTE(snapshotgt @ Feb 25, 2006 - 11:00 PM) [snapback]399639[/snapback]
~snap
Anyone know the generic bulb code or the toyota part number for the cig. lighter bulb? I am also trying to identify the codes for the money/ash tray bulb (the tray next to the handbrake, not the one under the aircon) and the boot (hatch) interior light.
Well, that's my first post. I'll be posting further bloody stupid questions from time to time.
This post has been edited by BloodyStupidDavey: Jun 16, 2007 - 12:09 PM
Lo-Fi Version Time is now: November 26th, 2024 - 8:30 AM
