![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 16, '04 From Los Angeles Currently Offline Reputation: 8 (100%) ![]() |
no one thought it was at least an ok deal or at least semi intresting.
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 29, '03 Currently Offline Reputation: 0 (0%) ![]() |
sorry to be the one that says it craig... but no one likes you.
![]() Enthusiast ![]() ![]() ![]() Joined Jul 5, '05 From Arlington, TX Currently Offline Reputation: 2 (100%) ![]() |
hmmmmm
it looks pretty nice, but the ebay description on it would scare me away .
" I ran it for only 5000 miles after the upgrade until I finally melted the pistons. " -------------------- 15PSI - 30MPG - Megasquirt Tuned
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 13, '02 From Blairstown, New Jersey Currently Offline Reputation: 6 (100%) ![]() |
Its a nice setup with the AWIC. I looked at a similar intercooler on EBay once but thought it was alot bigger than that.
-------------------- 3rd gen ST205 3SGTE - Alive and boosting. |
QUOTE(Chanh55 @ Feb 28, 2006 - 10:40 PM) [snapback]401015[/snapback] sorry to be the one that says it craig... but no one likes you. ![]() lol i love u man lol |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) ![]() |
I personally think that a good water to air intercooler setup is the best route for the MR2, where you don't really get much airflow out back.
-Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Enthusiast ![]() Joined Oct 6, '05 Currently Offline Reputation: 0 (0%) ![]() |
QUOTE(Dr_Tweak @ Mar 1, 2006 - 4:02 AM) [snapback]401262[/snapback] I personally think that a good water to air intercooler setup is the best route for the MR2, where you don't really get much airflow out back. -Doc hey doc, do you think this is worthwhile purchase? -------------------- Willy //2o9// California |
If you can score it cheap, yeah, it's a great starting point.
just keep in mind that the IC setup will not fit under the hood of a celica.
QUOTE(lagos @ Mar 1, 2006 - 1:33 PM) [snapback]401369[/snapback] just keep in mind that the IC setup will not fit under the hood of a celica. hes in cali, i already have begun negotiations since he is close to me, within 30 min... so if the auction doesent go well for him, i guess ill start my quest down the long road of Forced induction!... how much should i be trying to get this setup for? 700? 500? thanks in advance This post has been edited by Willy2o9: Mar 1, 2006 - 2:49 PM -------------------- Willy //2o9// California |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 10, '03 From Wichita, KS Currently Offline Reputation: 5 (100%) ![]() |
QUOTE(lagos @ Mar 1, 2006 - 12:33 PM) [snapback]401369[/snapback] just keep in mind that the IC setup will not fit under the hood of a celica. I bet it will if you relocate your battery and fusebox and do a little tweaking to the IC piping. I've seen it done on a 5th gen and it looks decent. Granted, it was a 3SGTE but I still think it's do-able. EDIT: Here it is: ![]() http://alltrac.net/phpBB2/viewtopic.php?t=12338 This post has been edited by WannabeGT4: Mar 1, 2006 - 3:35 PM -------------------- ![]() Project ST204.5 99.88946% complete... |
Enthusiast ![]() ![]() ![]() Joined May 1, '03 From Michigan Currently Offline Reputation: 0 (0%) ![]() |
Wow - now thats some ugly piping!
![]() -------------------- Scott
West Michigan |
QUOTE(WannabeGT4 @ Mar 1, 2006 - 3:20 PM) [snapback]401406[/snapback] QUOTE(lagos @ Mar 1, 2006 - 12:33 PM) [snapback]401369[/snapback] just keep in mind that the IC setup will not fit under the hood of a celica. I bet it will if you relocate your battery and fusebox and do a little tweaking to the IC piping. I've seen it done on a 5th gen and it looks decent. Granted, it was a 3SGTE but I still think it's do-able. EDIT: Here it is: ![]() http://alltrac.net/phpBB2/viewtopic.php?t=12338 the problem really isint with the intercooler, its with the stock mr2 piping that he includes in the kit. i tried to use mr2 piping before in my car, and found the, even with the higher gt4 hood, the piping is too tall and the hood will not close. where is the heat exchanger for that water to air IC? dont forget, the seller is putting his kit up for sale, becasue he did blow his motor. -------------------- 15PSI - 30MPG - Megasquirt Tuned
QUOTE(scothaniel @ Mar 1, 2006 - 2:56 PM) [snapback]401422[/snapback] Wow - now thats some ugly piping! ![]() LOL. Did you ever fix that? Otherwise it's a pretty impresive setup. QUOTE(lagos @ Mar 1, 2006 - 3:03 PM) [snapback]401425[/snapback] QUOTE(WannabeGT4 @ Mar 1, 2006 - 3:20 PM) [snapback]401406[/snapback] QUOTE(lagos @ Mar 1, 2006 - 12:33 PM) [snapback]401369[/snapback] just keep in mind that the IC setup will not fit under the hood of a celica. I bet it will if you relocate your battery and fusebox and do a little tweaking to the IC piping. I've seen it done on a 5th gen and it looks decent. Granted, it was a 3SGTE but I still think it's do-able. EDIT: Here it is: http://alltrac.net/phpBB2/viewtopic.php?t=12338 the problem really isint with the intercooler, its with the stock mr2 piping that he includes in the kit. i tried to use mr2 piping before in my car, and found the, even with the higher gt4 hood, the piping is too tall and the hood will not close. where is the heat exchanger for that water to air IC? dont forget, the seller is putting his kit up for sale, becasue he did blow his motor. Was that on a 5SFE though? Regardless it's still going to have to be tweaked a bit to get it just right. The piping that comes with the kit will push the intercooler to far from the motor so it's going to need to be redesigned any way. The intercooler looks like it'll fit without a problem though if it's done something like scothaniel's. -------------------- ![]() Project ST204.5 99.88946% complete... |
QUOTE the problem really isint with the intercooler, its with the stock mr2 piping that he includes in the kit. i tried to use mr2 piping before in my car, and found the, even with the higher gt4 hood, the piping is too tall and the hood will not close.. That turbo/ IC kit on ebay is pretty good. IC is probably efficiant for 350 HP and would cost around $700 new. The blown CT26 isn't worth much - I've seen good ct26's with upgrade selling for $400. As for IC piping, if it doesn't fit, make it fit! I used a front-mount kit from a Skyline on my wife's 6th gen, and I dont weld. I can operate a chop-saw though (pull down lever -ooooooo). You just put the IC where you want it and start cutting. -------------------- Scott
West Michigan |
QUOTE LOL. Did you ever fix that? Otherwise it's a pretty impresive setup. Yeah, I had.. then my engine cranked walk! Besides, form follows function. -------------------- Scott
West Michigan |
Lo-Fi Version | Time is now: April 23rd, 2025 - 6:58 PM |
