> How important is cleaning fuel injector??, cleaning fuel injectors???
post May 28, 2003 - 12:09 AM
PlanetFuzz
Joined Mar 9, '03
From Knoxville,TN
biggrin.gif How important is cleaning the fuel injector? I saw a place that cleans them for 40 dollars and I know STP has that stuff you put in it to clean it...anybody have any input?? Thanks
post May 28, 2003 - 1:28 AM
ghostdog
From ny to philly
as long as you use fuel injector cleaner like every other oil change you should be okay. on the otherhand if you've never run the cleaner through them they can get seriously clogged and you'll have to get them manually taken out and cleaned.
hope that helps.
post Jun 2, 2003 - 4:50 AM
Blackcelliman
Joined Nov 8, '02
From Narragansett,RI
If you normally use high octane fuel, that will help quite a bit to regularly clean the injectors. I put in 93 octane every time I fill up. I've never had a problem with my injectors.
post Jun 4, 2003 - 4:26 PM
exxtractor
Joined Mar 31, '03
From BC
From what I've read you are wasting your money putting in 93 octane. You might get a slight performance increase, but I don't think 93 octane in the end will make any difference in the life of your engine, most gasolines have detergents added. What I try and avoid are gasolines with methanol added (corn byproduct). That stuff in my opinion will gum up an engine, though it reduces emmissions. I like to use valvoline SynPower line of fuel injector and fuel system cleaner but its wa more expensive compared to penzoil's prodcuts.
post Jun 4, 2003 - 4:35 PM
CelicaGoddess
Joined Apr 2, '03
From Atlanta
I heard this morning on the radio that if you buy 1 bottle of STP fuel injector cleaner at AutoZone, you can get a second one free or something like that. It may have been that for 2 bottles you pay 3.99. Either way, its a good deal.
I've heard that you're supposed to clean em every 3,000 or 6,000 miles. But if thats true and you're supposed to do it that often, I'd say its pretty important. Definately can't hurt your gas milage (?sp) tongue.gif
post Jun 4, 2003 - 7:09 PM
kyle314
Joined Nov 4, '02
From montrose colorado
we have a BG machine in the shop that will clean the injectors without taking them out takes about 45 min.
post Aug 10, 2004 - 10:18 AM
1900WattCelica
Joined Jul 7, '04
From Germantown, WI
I have a 93 Prizm (Corolla Twin - 16 Valve 4A-FE BABY!) and my car was idling really rough and while driving it, if i got on the throttle too fast the car actually went slower haha. Anyway me and my pa unplugged the harness from each of the injectors individualy and one of them didnt cause the engine to bog down any more than it already was when it was plugged, while the other 3 did slow down the idle. I was on my way to Goodyear to have it checked it out and have the injectors cleaned (100 dollar service) when I decided to stop at a auto place and try the STP fuel injector cleaner in the black bottle. I poured it in and started the car up and it was idling rough and the engine hesitated when i got on the gas, but I revved it up slowly to like 5000 rpms and kept on it for about 15 seconds, slowly let off and then let it idle. It idled perfectly and I went for a drive. Every stop light I stomped the gas and she purred and got right up and went man. I was never a huge believer in gas additives but this stuff worked haha. Saved me $97.50.
(p.s. I had 5 gallons left in the tank. Directions say one bottle treats 21 gallons biggrin.gif )
post Aug 10, 2004 - 10:23 AM
95BlueGT
Joined Aug 30, '02
From Austin Texas
fill up with 93 and floor it, it'll clear ur injectors.
post Aug 10, 2004 - 11:28 AM
QUOTE (exxtractor @ Jun 4, 2003 - 5:26 PM)
If you buy 93 for performance, yes ur wasting ur money, but it does help keep the engine "extra" healthy. It helps prevent knock, and the engine will burn cleaner and more efficiently off of it, but keep in mind our ECUs were designed for 87.
post Aug 10, 2004 - 11:45 AM
bufferdan
Joined Nov 9, '03
From Dayton, OH
dude...you wont get knock on regular gas unless your timing is off or other stuff is wrong. These cars are designed to burn regular gas to its full extent.
post Aug 10, 2004 - 12:24 PM
Dude knock happens, more than you think. It just doesnt happen constantly.
Nobody said u will get knock on 87, u totally missed the point, dude.
post Aug 10, 2004 - 12:36 PM
bufferdan
Joined Nov 9, '03
From Dayton, OH
I think i got the point... You shouldnt be knocking if everything is right. You can cover pinging and knock sometimes though with high octane gas. But you are just covering up a problem.
post Aug 14, 2004 - 2:17 AM
exxtractor
Joined Mar 31, '03
From BC
I try not to buy 93 or 94 octane here, many refineries add ethanol to gasoline, but for regualr 87. I remember driving across the U.S.. and there were a few areas where 87 was more expensive than say 91 becuase there was no ethanol added and thus the price was more.
post Aug 14, 2004 - 5:36 AM
Rjb23
Joined Feb 8, '04
From KY
QUOTE (Blackcelliman @ Jun 2, 2003 - 9:50 AM)
This is a huge myth! Will it not die!!
Higher octane only means that the fuel can take more pressure before exploding. This is why it is used in high compression engines.
If your car is knocking you have something else wrong with it, unless it was designed for higher octane fuel.
post Aug 14, 2004 - 6:45 AM
unless your engine is designed for higher octain fuel, then use plain old 87.
for me, im forced to find the highest octain i can for my 3sgte.
post Aug 14, 2004 - 10:08 AM
97Celica
Joined Nov 27, '02
From Derry,NH USA
I run 93 Octane daily and 97 at the track...I used fuel additives every 3k miles and fuel injector cleaners...oil additives..the whole 9..The ONLY part I have had to ever replace in my car was my EGR valve becaused it was clogged.
post Aug 14, 2004 - 10:27 AM
celicaboston1983
Joined Mar 20, '04
sure our car takes 87 the manual saids 91 or higher
post Aug 14, 2004 - 4:18 PM
Rjb23
Joined Feb 8, '04
From KY
QUOTE (97Celica @ Aug 14, 2004 - 3:08 PM)
87 is better for your car.
Gt's take 89 and st's take 87 octane.
Lo-Fi Version Time is now: February 17th, 2025 - 1:18 PM
