> GT4 HOOD with other front bumper?, HELP..opinon needed if you know...
post Feb 27, 2006 - 3:27 AM
chacha
Joined Dec 29, '05
From So-Cal
Do i have to buy new side fenders along with other parts to have GT4 hood on without that nasty gap? Basically, can i just buy the GT4 hood and slap on the new front kit on, thus removing the OEM bumper...will this still cause the front of the celica to have a nasty gap? I read the sticky, but it mention nothing about the hood mix in with other kits or if i needed to buy any new fenders with the hood for fitment..thanks for your help!
post Feb 27, 2006 - 3:39 AM
Defgeph
Joined Apr 17, '03
From Rockland NY
unless the new bumper is designed for the gt4, you'll have the gap.
I will return one day.
post Feb 27, 2006 - 3:40 AM
jayi12-15psi
Joined Jan 9, '03
From St. Louis
You would need to buy a kit that's specifically for the gt-4. Most of these kits are only available in europe/japan. Otherwise, if you buy a vis kit there will be a gap. If you look at neverstop's profile you can see that the gap isn't that bad, I think it looks kinda good on his kit. As far as fenders go, you'll have no problem either way. The only dif between U.S. fenders and others is the placement of the side indicator. It's up by the door on J-spec/euro and in front of the wheel well on the U.S. spec. Hope this helps.
post Feb 27, 2006 - 4:15 AM
chacha
Joined Dec 29, '05
From So-Cal
hey..thanks! now i wished i just bought the kit for the GT4...lol, guess i should have asked before i did it. How about buying the hoods that are made for ST204 but have the GT4 look to it? will this make a differ? first of all, is there such a thing?
post Feb 27, 2006 - 6:28 AM
trdproven
Joined Aug 2, '05
From Guam
i believe its the c-one kit if Im not mistaken if you want the gt4 look.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Feb 27, 2006 - 6:50 AM
CelicaZR
Joined Mar 25, '05
From Sydney, Australia
I believe you cant have the GT-4 hood without the GT-4 bumper or vice versa without the gap.
You can use the C-One bumper with the GT-4 hood.
6GC 4 Life Baby!!!
post Feb 27, 2006 - 8:21 AM
b1gr3d
Joined Feb 25, '03
From Springfield, MO
what about zachattack? http://www.6gc.net/index.php?action=members&itu=2967 he has a zyclone front with a stock hood and it looks pretty good
Coming in 2010
post Feb 27, 2006 - 9:21 AM
94gts
Joined Aug 28, '02
From B.C. Canada
QUOTE(b1gr3d @ Feb 27, 2006 - 5:21 AM) [snapback]400360[/snapback]
That kit is is designed to line up with the stock hood, it's not ment for a GT4. The c-one kit they were refering to was the GT4 kit which has a bulge between the head lights. Take a little peek in the part database and look at the differences your self, is quite obvious why mixing and matching hood and bumper combo's won't work when your using GT4 parts.
post Feb 27, 2006 - 10:18 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
^ He could get the zyclone kit and then get the Carbon Fiber Zyclone hood. Like Chanh. GT-4 front without the bulge.
**** Photobucket
post Feb 27, 2006 - 10:48 AM
chacha
Joined Dec 29, '05
From So-Cal
i see, so i must get the c-one front specifically for the GT4, so there won't be a gap right, and if i do not, the regular c-one for the ST204 with the GT4 will still give me a gap? why can't the chasis for all 6GC be the same...makes it so much easier! Thanks again you guys/gals for the opinions!!
post Feb 27, 2006 - 11:54 AM
jayi12-15psi
Joined Jan 9, '03
From St. Louis
that's correct, the hoods are different to account for the gt-4's top mount intercooler(TMIC).
post Feb 27, 2006 - 6:28 PM
Green_MachToy
Joined Mar 21, '04
From Oceanside
QUOTE(chacha @ Feb 27, 2006 - 8:27 AM) [snapback]400313[/snapback]
The GT4 fenders are a little wide around the tires, but the lines around the hood are the same as your stock fenders. No need to do anything there unless you want. The only difference is like everyone said...in the hood and front bumper.
post Feb 27, 2006 - 8:05 PM
chacha
Joined Dec 29, '05
From So-Cal
I now know there will always be a gap, but last question: Is there something that i can possibly do to cover that gap up, like that rubber protector between the hood and top end front bumper? *I really want the GT4 hood that i will soon order, but i have already bought the c-one front bumper and want a clean installation look with the GT4 and c-one bumper made for the ST204... frown.gif
post Feb 27, 2006 - 9:40 PM
b1gr3d
Joined Feb 25, '03
i think it was mentioned before but why don't you get a zyclone hood?
Coming in 2010
post Feb 27, 2006 - 9:56 PM
chacha
Joined Dec 29, '05
From So-Cal
to be honest...i don't really like that hood look...
post Feb 27, 2006 - 9:57 PM
94gts
Joined Aug 28, '02
From B.C. Canada
a half inch gap over a foot long isn't something you just hide ... try a bra that might work...LOL
post Feb 27, 2006 - 10:11 PM
b1gr3d
Joined Feb 25, '03
http://www.6gc.net/index.php?action=parts&itu=48
what about that hood? made by c-one looks almost just like the gt-4 hood but w/o the muddle hump
Coming in 2010
post Feb 27, 2006 - 10:16 PM
94gts
Joined Aug 28, '02
From B.C. Canada
Your right that hood is made for non-GT4's. c-one makes both styles. Your might not want to see the price of that hood though...bulletproof
post Mar 4, 2006 - 12:11 AM
urbandork
Joined Jul 16, '04
From Los Angeles
i never figured out why ppl just dont get a gt4 hood and then a zyclone hood.... Then get a peice of foam shave/shape it a buldge to match the hood and then fiber glass and finish it off.
I was thinking about this but then found a gt4 hood taht came with a bumper and jdm side fenders.
post Mar 4, 2006 - 12:30 AM
madmods
Joined Mar 19, '04
From Scottsdale, Az
You could always do what neverstop did. Cut the bumper, and raise it up to match the hood and reglass it.
Lo-Fi Version Time is now: February 23rd, 2025 - 8:55 PM
