> car won't start... occasionally, looking for ideas on where to look.
post Feb 27, 2006 - 9:28 PM
Tweek
Joined May 4, '04
From Panama City Beach, FL
I am having this wierd starting problem that I can't figure out. Every once in a while... maybe once a month or longer, it just won't start. There seems to be power to everything, not even a dimming of lights at all. I've even checked the battery on my charger and there is plenty of juice. It does not even attempt to turn over. It seems like it just fixes itself after 10 minutes or so and starts up great. Then it doesnt happen again for a while.
Any ideas?
post Feb 27, 2006 - 9:39 PM
axelrduvirage
Joined Feb 8, '06
From Nova Scotia, Canada
i have a 99 gt with the same problem...goes away if i drive it every day. seems the choke is all weird and fixes itself if i put it in drive and roll a few kilometres
BTW nice sig
post Feb 27, 2006 - 10:02 PM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
Is it really not even turning over? If that's the caise, it's just a short. If you let a car sit for a couple days or so, it will pick up mosture. This makes shorts and other things happen easier.
Live Free, Be Happy
check the connections to the igniter. Unplug it and plug it back in and make sure it is connected securly.
post Feb 27, 2006 - 10:33 PM
StreetRacing10PS...
Joined Oct 10, '04
From New Jersey
check the starter, that was the problem wit mine. also, how old is the battery. it says you live in FL so iam guessing the cold would have nothing to do wit it cuz on my jeep the same thing was happening but it was only because the battery was old and wouldnt turn over due to the weather.
post Feb 27, 2006 - 10:46 PM
94gts
Joined Aug 28, '02
From B.C. Canada
check the contacts in the starter, they wear out. When mine went the car would randomly not start like that. It's just little copper contacts they are super cheap too, if that is the case.
post Feb 27, 2006 - 11:59 PM
Tweek
Joined May 4, '04
Thanks for the tips, I'll give them a shot.
Its not like I left the car not running for days. Its like I stop at a gas station to grab a pack of smokes or some gas and it doesnt start back up. Its wierd. Its not really that old of a battery, 6 months to a year. And like I said, the power is fine even when it wont start. The prob is that it wont even try and turn over. No clicking, sputtering... just nothing.
I'll let you know if I find anything. Thanks again for the tips.
post Feb 28, 2006 - 12:05 AM
QUOTE(Tweek @ Feb 27, 2006 - 11:59 PM) [snapback]400721[/snapback]
post Feb 28, 2006 - 2:08 AM
hitcachi
Joined Jun 19, '05
From Nebraska
Mine did this also. New starter fixed everthing.
post Feb 28, 2006 - 2:30 AM
QUOTE(Batman722 @ Feb 28, 2006 - 12:05 AM) [snapback]400722[/snapback]
x2 check the ignitor harness plug!
post Mar 2, 2006 - 3:42 PM
nightryder
Joined Sep 29, '05
From Rochester, Massachusetts
yes check that plug, jiggle it a little bit when you are trying to start it, a few of us (lagos and myself) have had this problem. check check
The question is not how far. The question is, do you possess the constitution, the depth of faith, to go as far as is needed?
post Mar 2, 2006 - 4:29 PM
Doge
Joined Dec 2, '02
From Portland, Oregon
Check starter connections. Easy to short out...
post Mar 4, 2006 - 6:10 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
check starter, check igniter, ect. those are fine. it has to be a fuse or a meesed up wire in the harness. everything is plugged in and i dont have power windows, radio, ac/heat, so thats a matter of a fuse. right... do i need to swap relays and fuses from the interior JDM clip? everything is plugged in... Hmm batman when u see this call me tongue.gif hahah wrong thread. my bad
This post has been edited by x_itchy_b_x: Mar 4, 2006 - 6:12 PM
Lo-Fi Version Time is now: November 23rd, 2024 - 3:57 AM
