> power antenna, i killed it
post Mar 1, 2006 - 12:35 AM
celicaST
Joined Jun 23, '05
nothing exciting, just unplugged my power antenna the other day. got sick of driving with it up when i hardly ever listen to the radio, but actually i still get reception to the one station i listen to anyways lol. plus its nice not to hear that annoying thing go up and down. so if anybody else wants a quick fix to keep it down, just remove interior trim panel and kill it! smile.gif
post Mar 1, 2006 - 12:53 AM
cg97
Joined Nov 30, '05
From British Columbia, Canada
my antenna stays down until i switch the deck from cd to tuner
post Mar 1, 2006 - 1:28 AM
dlx742
Joined Oct 10, '05
From San Diego
QUOTE(cg97 @ Mar 1, 2006 - 12:53 AM) [snapback]401210[/snapback]
yah mine too... but i still hate the noise it makes when it goes up
post Mar 1, 2006 - 2:21 PM
Jaws4God
Joined Mar 27, '04
mine goes up when the headunit is on... doesn't matter which section (cd or mulitdisc or tuner) so I just ran it to a switch...
post Mar 1, 2006 - 3:16 PM
jdg371
Joined Jun 14, '05
not to jack the thread but...
My antenna wont seem to go up..Head Unit is on but it wont go up..
post Mar 1, 2006 - 6:46 PM
BLINKYxMUNKEY
Joined Nov 12, '03
From Crestview, Florida
Mmm.. Mine broke. It stopped going up and down. I never listened to the radio anyways. Then I had to unplug it to keep it from making the noise of trying to raise the antenna.
FlickR
post Mar 1, 2006 - 6:55 PM
celiracer
Joined Oct 5, '05
From NE
i wish i could find a way to make mine go up just when the tuner is on. and go down when the cd's are playing
post Mar 1, 2006 - 7:43 PM
afroman
Joined Feb 9, '03
From Sioux falls, South Dakota
you can most decks have a power antena wire just for that reason
-Aaron--
post Mar 2, 2006 - 2:06 AM
Silver94CelicaOw...
Joined Oct 13, '02
From Blairstown, New Jersey
Haha, I killed mine also....except not only did I unplug it but I shoved the antenna back into itself against its will since I never used my radio. Only CD's, IPod, or Sirius anymore for me.
post Mar 5, 2006 - 11:23 AM
94GT
Joined Feb 25, '04
From Fairfield, CA
QUOTE(celiracer @ Mar 1, 2006 - 5:55 PM) [snapback]401513[/snapback]
It turns out that the stock power antenna is pretty complicated. If the stock stereo (at least the '94 premium sound one that I've got) is powered off and you let the antenna go down, and then just press the cd button to power it back up, the antenna will stay down. However, if you are listening to the radio, then insert a cd or press the cd button with a cd in the deck already it will remain up while you are listening to the cd until the deck is powered off or the car is turned off.
Mine now does what you are talking about because I had to replace my antenna with a generic one. The generic one only needs a +12v line to power the unit (thicker heavier gauge wire), a negative (you can just ground it to the chasis for this one since that's where you're negative battery cable is grounded), and a signal wire. The signal wire is thinner because it isn't designed to carry the juice to operate the antenna but it is also +12v. Also, the thicker +12 supply line is always hot so that the antenna can still go down after you've pulled the key out of the ignition. You need a multimeter and a buddy so that you can start probing the wires on the stock harness that is connected to your old power antenna so you can figure out which signal wire you want to use. There are roughly five of them and they all tell the stock power antenna unit something different.
1. Ignition is on
2. There is power to the stereo
3. The tape deck is on
4. The cd player is on
5. The AM-FM tuner is on
When any of these things happen, the respective signal wire gives out +12 v on the multimeter. I then cut wire number 5 and wired it up to my new antenna. That way the antenna will only go up if and only if the radio is playing. The second I press the cd button, tape button, or turn the radio off or the car off, wire number 5 loses it's 12 v and as a result the antenna uses the juice off of the 12 v supply wire to lower itself.
I know the wheels are probably turning on how to do this with your stock power unit, but I caution you. The easy way would be to cut wires 1-4, but if you do that it might not work right (when you start taking apart the stock antenna you realize it's got it's own little brain (the brown box) that interprets the signals and figures out whether to put the antenna up or down). I'm not saying don't try it, but don't do anything that can't be undone.
The generic power antenna unit cost me 45 dollars at Advance Auto Parts part number ATPW22
I also googled it and found it online listed as: METRA 44-PW22 UNIVERSAL POWER ANTENNA at various online shops (all priced around 40-45. Circuit City wanted 99)
post Jul 23, 2008 - 6:47 PM
luka
Joined Jul 23, '08
From Hawaii
remember which color wire was #5?
had to replace my antenna also.
post Jul 23, 2008 - 11:26 PM
Athorn
Joined Jan 4, '08
From Clearwater, Fl
Probley one of the cheapest..easiest mods you can do. The S200 antenae.
post Jul 24, 2008 - 12:02 AM
96bluevert
Joined Mar 19, '07
From Washington
QUOTE (Athorn @ Jul 23, 2008 - 9:26 PM) *
easy, definately..cheap, that depends where you get the antenna. I just went straight to the Honda dealership and bought one. Cost about $30 there. But there are some going for like $10 on ebay.
post Jul 27, 2008 - 5:36 PM
AnaXyd
Joined Jul 15, '08
From Norway
Do you have a link for the antenna on Ebay? My AT200 antenna is broke too, and I want to replace it.
post Jul 28, 2008 - 9:53 AM
96bluevert
Joined Mar 19, '07
From Washington
here's one:
http://cgi.ebay.com/ebaymotors/HONDA-S2000...p3286.m14.l1318
that's not the only antenna that will work, though. There are some others that you can get on ebay that are different sizes and what not..The S2K one just looks best imo.
post Jul 29, 2008 - 10:53 AM
AnaXyd
Joined Jul 15, '08
From Norway
This is a total replacement for the motorized one, right? I think my motor is broke, or maybe its not connected. What kind of cable is the motor assigned to?
post Jul 29, 2008 - 10:56 PM
96bluevert
Joined Mar 19, '07
From Washington
No, just the visible part of the antenna. You'll also need another 6th gen base or a 7th gen base would work too...here's the how-to:
http://www.6gc.net/howto/install_s2000_antenna
post Aug 2, 2008 - 6:08 PM
AnaXyd
Joined Jul 15, '08
From Norway
Ah, nice. This is a great facelift, right? Maybe I'll just put this on instead of buying a new motor.
The bidding has ended for that item you linked me. Can you find a proper one, which can be shipped to Norway? smile.gif
post Aug 2, 2008 - 8:17 PM
Tech-Nics
Joined Jun 18, '08
how do you unplug it? Cause mine is also broken and it makes a horrible noise when the turn on the radio.
post Aug 9, 2008 - 6:35 AM
AnaXyd
Joined Jul 15, '08
From Norway
I fant find a seller who sells this antenna, who can ship to Norway.. Someone?
Lo-Fi Version Time is now: January 10th, 2025 - 2:08 AM
