Enthusiast Joined Feb 8, '06 From Ensenada B.C Mexico Currently Offline Reputation: 0 (0%) ![]() |
my celica has a sunroof/moonroof , and it can be opened in 2 ways, open the whole window, that mean the moonroof will slide inside the top, and the other way is to open it a little bit upper, I was wondering if can be possible to open the moonroof all the way out! , I saw once a 6gc that had it opened all the way out! but just once!
do they came that way from the dealer or that guy made it so!? can I make my own that way!? looks a lot better! thanks! ![]() |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 5, '05 From NE Currently Offline Reputation: 6 (100%) ![]() |
Do you mean yours goes open all the way and goes inside the top? and you've seen one that opens and goes above the top of the car instead of inside the car?? if so.. I think just the anaversery additions came with that.. Don't know for sure tho.
no stock unit opens like that the one you saw was an aftermarket unit
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 27, '04 Currently Offline Reputation: 14 (100%) ![]() |
![]() like that? -------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 23, '05 Currently Offline Reputation: 4 (100%) ![]() |
QUOTE(Jaws4God @ Mar 1, 2006 - 11:05 PM) [snapback]401683[/snapback] ![]() like that? no, he means like when it slides back over on top of the outside of the car, not in it. like playr said, no oem roofs opened like that. here is what he is talking about 94silverst ![]() This post has been edited by celicaST: Mar 2, 2006 - 1:21 AM -------------------- ![]() I think Bigfoot is blurry, that's the problem. It's not the photographer's fault. Bigfoot is blurry. And that's extra scary to me, because there's a large, out-of-focus monster roaming the countryside. |
Right!!! I mean like the 94silverst that slices back on the top, there is any way to make mine to open it out side over the top!? I think it looks a lot better! , 'cause mine slices inside the top as Jaws4God posted.
thanks |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 10, '04 From Shoreline, WA Currently Offline Reputation: 4 (100%) ![]() |
um I think sliding it in under the top is better, so you dont have thing thing hanging over your roof but its nicly hidded in the roof. but like other people are saying, none do both, because the way the trac/sliders are set up you cant have it pull up and out and have it slide in. plus it would probably be very hard to swap one kind for the other.
I think the one that slides out over the top is a manual one too, not a power slide but I'm not sure This post has been edited by creis: Mar 2, 2006 - 9:46 PM -------------------- ![]() |
Lo-Fi Version | Time is now: April 24th, 2025 - 12:58 AM |
