![]() Enthusiast ![]() Joined Dec 22, '05 From Turlock, CA Currently Offline Reputation: 0 (0%) ![]() |
I have previously seen some pictures of the b16 T3 turbo exhaust manifold on a 7AFE engine. I would like to know If anyone can tell me what modifications I need to make to the flange in order to make this work. ANY input is appreciated. This is the manifold I want to get on ebay at:
http://cgi.ebay.com/ebaymotors/NEW-Civic-I...041461498QQrdZ1 -------------------- www.cardomain.com/id/snakesolid
![]() Enthusiast ![]() ![]() Joined May 24, '03 From Andrews TX Currently Offline Reputation: 1 (100%) ![]() |
I posted a topic over this a while back I'll see if I can find it for you
-------------------- If anyone is missing NASCAR and it's not on Speed Channel, take a fistful of Skittles, throw them in the toilet and hit the flush handle. Instant NASCAR!!!
its in teh STICKIES
![]() you have to cut the manifold's flange off (the engine side) and weld on a 7afe flange (runner extension might be needed) flanges available from jgstools.com/turbo also you need to reinforce the welds on that manifold as they are know to crack and a brace (if it doesn't come with one) should be welded from flange to flange to aid in support |
in the stickies I beleive that that is Nik's manifold which is the 4AGE head for his 7AGTE as for the 7AFE you will have to move the exhaust runners that connect to the JGS flange, you will especially have to move the runners from thew #1 & #4 cylinders
on the post that I had made some one (sreetracing10-12psi I think ![]() BUT basically the 4AGE head lines up but the 7AFE has to be modifeid quite a bit -------------------- If anyone is missing NASCAR and it's not on Speed Channel, take a fistful of Skittles, throw them in the toilet and hit the flush handle. Instant NASCAR!!!
actually i wrote 1 of the stickies the one which i mentioned in my last reply and it was clements car which is a 7afe
Thanks for the info this will help tremendously.
![]() -------------------- www.cardomain.com/id/snakesolid
Lo-Fi Version | Time is now: April 23rd, 2025 - 6:58 PM |
