throttle body and turbo outlet size, for intercooler reducers |
Mar 3, 2006 - 12:33 PM |
Enthusiast Joined Mar 3, '04 From Hollywood, MD Currently Offline Reputation: 6 (100%) |
about to order my piping for intercooler, and i need to buy reducers too i assume. im going with 2.5" pipe, what size reducers do i need? thanks. this is for a 3sgte
-brian |
Mar 3, 2006 - 4:29 PM |
one thing people forget to mention, is that you will need the throttle body inlet and gasket from an mr2 turbo, in order to correctly hook up the piping to the throttle body. thats 2.5in, so youll be fine if you piping is the same size. the turbo, on the other hand needs a 2in reducer. problem is, that you sort of need a silicone 45degree there. if i were you would order a short straight 2in piece and then a normal 45degree and stick the 2in inside it to make your own recuder. this works great and it a lot cheaper then the cost of having a 45deg reducer made.
Mar 3, 2006 - 4:48 PM |
i might have those pieces? since i bought the motor from someone who had it in a celica. the throttle body inlet and gasket from an mr2 turbo
Mar 3, 2006 - 6:31 PM |
Enthusiast Joined Sep 30, '02 From Washington Spokane / Coeur D' Alene Idaho Currently Offline Reputation: 11 (100%) |
i have a bunch of 90 degree mandrel bent piping if you need some pm me
-------------------- yea your 3sgte is cool but ill stick to my 7agte
Mar 3, 2006 - 8:25 PM |
i think im buying all my pipe from roadraceengineering, they got a 90* bend two for one special at 26 bucks right now. i need 4 of them, plus i want it to be all the same piping haha
Lo-Fi Version | Time is now: December 3rd, 2024 - 7:20 PM |
