> 3sgte Swap Complete!!!
post Mar 3, 2006 - 6:19 PM
gtfc115
Joined Aug 14, '04
From Toledo, Ohio
well today was the best day in a LOOONG time (about 2 years). i got a call from my guy at the shop and he said the swap was done. OH JOY.
i picked it up and went driving around for a few hours...not really beating on it too bad, but i was giving it some gas a few times. wow this thing is awesome. its tough to find the gears sometimes (i need to re-do my mr2 tranny shifter conversion). and i need to grind down the passenger side engine mount cuz its resting on the timing gear cover.
so now here's the first inevitable problem...i was on my way home on a country road and stepped on it a little, and it died. at first i thought it just stalled so i tried to start it back up, and it died again. i pull over and started it and it idled ok, but if i even touched the gas a little, it died.
i called the shop and he said it sounded like my fuel pump went out. does that sound right to you guys? i was expecting this to happen cuz i was using my 7afe fuel pump (i know, BAD idea). so now's my chance to get a new one.
post Mar 3, 2006 - 6:30 PM
nik
Joined Sep 30, '02
QUOTE(gtfc115 @ Mar 3, 2006 - 5:19 PM) [snapback]402354[/snapback]
wow that is really stupid you put all that money and time into a swap and dont upgrade the pump
post Mar 3, 2006 - 6:33 PM
gtfc115
Joined Aug 14, '04
From Toledo, Ohio
QUOTE(nik @ Mar 3, 2006 - 11:30 PM) [snapback]402359[/snapback]
so did i blow the motor? it didnt sound bad...it just died
and yeah, i know it was stupid...
post Mar 3, 2006 - 6:35 PM
If the car started up and idled fine I dont think you blew your motor.
Replace that fuel pump asap or you will blow it, it was unwise of not only you but the mechanic to not upgrade the pump.
post Mar 3, 2006 - 6:37 PM
gtfc115
Joined Aug 14, '04
From Toledo, Ohio
well it was my fault...he didnt know anything about the swap before i brought my car to him.
im going tomorrow morning to talk to him. i doubt he'll have a new pump in there by then, so i'll make sure he gets a bigger one.
post Mar 3, 2006 - 6:47 PM
gtfc115
Joined Aug 14, '04
From Toledo, Ohio
oh, and i should post this in the other thread. but the short axle solution worked for me. get another axle and use that part as a spacer, get longer bolts, and you're set.
post Mar 3, 2006 - 6:54 PM
you probably have a vac leak causing you car to stall out
post Mar 3, 2006 - 6:58 PM
j0e_p3t
Joined Dec 8, '05
From torrance/carson, ca
hold up... it took 2 years to do the swap?
post Mar 3, 2006 - 10:57 PM
gtfc115
Joined Aug 14, '04
From Toledo, Ohio
QUOTE(j0e_p3t @ Mar 3, 2006 - 11:58 PM) [snapback]402371[/snapback]
yea, my first mistake was gettin an mr2 clip...and then none of the shops around here know how to do the swap (well 1 does now) and a lot of LOOONG stories in between....****ing nightmare.
QUOTE(lagos @ Mar 3, 2006 - 11:54 PM) [snapback]402369[/snapback]
well its already at the shop, but is there an easy way to check for that? either way, its getting a new fuel pump.
post Mar 3, 2006 - 11:07 PM
StreetRacing10PS...
Joined Oct 10, '04
From New Jersey
check your boost guage. if you are running less then 20PSi of vac. you have a leak
post Mar 3, 2006 - 11:30 PM
snapshotgt
Joined Oct 12, '05
From Texas
...does not sound like your swap is complete wink.gif Good luck sorting it out!
snap
gtfc115
Joined Aug 14, '04
From Toledo, Ohio
QUOTE(StreetRacing10PSI @ Mar 4, 2006 - 4:07 AM) [snapback]402439[/snapback]
post Mar 3, 2006 - 11:48 PM
CelicaZR
Joined Mar 25, '05
From Sydney, Australia
I hope you get everything sorted out.
6GC 4 Life Baby!!!
post Mar 4, 2006 - 12:16 AM
QUOTE(gtfc115 @ Mar 3, 2006 - 11:30 PM) [snapback]402444[/snapback]
what do u mean? you are not getting vac...or you bought a gauge that dosnt read vac?
i recomend you sign up to mr2oc.com and start reading every single post.
post Mar 4, 2006 - 12:31 AM
haha, every single post.
post Mar 4, 2006 - 12:34 AM
madmods
Joined Mar 19, '04
From Scottsdale, Az
QUOTE(gtfc115 @ Mar 4, 2006 - 3:57 AM) [snapback]402434[/snapback]
Hope you get it figured out. I'm curious why the mr2 clip was a mistake?
post Mar 4, 2006 - 12:36 AM
QUOTE(Supersprynt @ Mar 4, 2006 - 12:31 AM) [snapback]402468[/snapback]
yes. every single post, or untill your eyes start to bleed. whatever happens first. its the only way to learn about the 3sgte.
madmods, have you read any of the posts that have been going on about the mr2 vs st185 clip ?
post Mar 4, 2006 - 12:42 AM
madmods
Joined Mar 19, '04
From Scottsdale, Az
QUOTE(lagos @ Mar 4, 2006 - 5:36 AM) [snapback]402473[/snapback]
no, whats up with them? I thought using the clip was the way to go. whats the right clip?
post Mar 4, 2006 - 12:47 AM
just read the thread below this one.
post Mar 4, 2006 - 12:55 AM
madmods
Joined Mar 19, '04
From Scottsdale, Az
QUOTE(lagos @ Mar 4, 2006 - 5:47 AM) [snapback]402476[/snapback]
Alright, got it. I thought that was the motor all you guys were using. I read this:
1st Generation - 190 HP(USDM '87-'89 Celica All-Trac), 187 HP(JDM '87-'89 Celica GT-Four)
2nd Generation - 200 HP(USDM '90-'93 Celica All-Trac, USDM '91-'95 MR2 Turbo), 221 HP(JDM '90-'93 Celica GT-Four, JDM '89-'94 MR2 Turbo), 231 HP(JDM '90-'93 Celica GT-Four RC)
3rd Generation - 239 HP(Non-JDM '94-'99 Celica GT-Four), 241 HP(JDM '95-'99 MR2 Turbo), 251 HP(JDM '94-'98 Celica GT-Four)
4th Generation - 254 HP(JDM ST246 Toyota Caldina GT-Four)
Found this at the feasible swap section and thought hmm mr2 the way to go. So are most people using the
all-trac?
Lo-Fi Version Time is now: February 22nd, 2025 - 6:01 PM
