Anybody done a powersteering pump? |
Mar 4, 2006 - 3:54 AM |
Enthusiast Joined Mar 19, '04 From Scottsdale, Az Currently Offline Reputation: 2 (100%) |
Anybody done a power steering pump? I got to tackle one, and a clutch and radiator so the camera will
be out for a how to. Any tips on the power steering pump? Is it an o-ring or gasket behind it? |
Mar 4, 2006 - 4:23 AM |
what do you mean done a power steering bump?
like remove and install? i believe its just pressure fitting on there that holds the line to the pump, either that or a copper washer/gasket. |
Mar 4, 2006 - 5:52 AM |
QUOTE(Hanyo @ Mar 4, 2006 - 9:23 AM) [snapback]402512[/snapback] what do you mean done a power steering bump? like remove and install? i believe its just pressure fitting on there that holds the line to the pump, either that or a copper washer/gasket. Yea, I am going to replace it with a new one. I was wondering what I have to remove to get to it. |
Mar 4, 2006 - 11:13 PM |
Enthusiast Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) |
Yeah it's not too bad, disconnect the lines and let it drain, then get up in there with a wrench and unbolt it... it's only like two bolts, but they're hard to get to. Have fun
And make sure the car is securely on jackstands! -doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Lo-Fi Version | Time is now: November 23rd, 2024 - 10:49 AM |
