Engine won't start, help me |
Mar 5, 2006 - 2:44 PM |
Enthusiast Joined Jun 12, '05 From Box Springs, GA Currently Offline Reputation: 0 (0%) |
okay, it was running fine earlier. I had cleaned my engine compartment with a degreaser. afterwards, i rinsed everything with the hose. now it won't start!!
the starter works fine. it cranks, but won't turn over. please help. -------------------- |
Mar 5, 2006 - 4:33 PM |
Mar 5, 2006 - 4:47 PM |
Enthusiast Joined Jun 29, '03 Currently Offline Reputation: 0 (0%) |
You rinsed your engine with a hose? You're crazy man.
Mar 5, 2006 - 5:06 PM |
Enthusiast Joined Jan 6, '06 From Michigan Currently Offline Reputation: 0 (0%) |
pull the distributor cap off and see if there is water in there.
Mar 5, 2006 - 5:50 PM |
Enthusiast Joined Jan 1, '05 From rapid city, SD Currently Offline Reputation: 0 (0%) |
Honestly check everything to make sure nothing has gotten inside of anything internally.......for ex: your distributer, airbox (cai); make sure no water has gotten inside connectors ( btwn were the male and female ends meet), if at most you might gotten the wrong thing wet, and now it might just need to be dried..........
Mar 5, 2006 - 6:06 PM |
QUOTE(Chanh55 @ Mar 5, 2006 - 4:47 PM) [snapback]402969[/snapback] You rinsed your engine with a hose? You're crazy man. yea, i kno. but what else would i use to RINSE it? just following the advice of some friends who do the same thing and have no problems. QUOTE(Elevindie @ Mar 5, 2006 - 5:06 PM) [snapback]402978[/snapback] pull the distributor cap off and see if there is water in there. thanx, man. i forgot about that. now i can get to school tomorrow. i after i rinsed it, i blew all the remaining water out and dried it. i checked the electrical connections and stuff. some stuff was still damp so i waited for EVERYTHING to dry. it's not like i took a pressure washer to it. i'll just have to remember the distributor next time. -------------------- |
Mar 5, 2006 - 6:09 PM |
I would've wipe it off with a damp rag. Glad you found the problem though. Did you take any before and after pics?
Lo-Fi Version | Time is now: November 23rd, 2024 - 4:23 AM |
