![]() Enthusiast ![]() ![]() Joined Jan 13, '06 Currently Offline Reputation: 0 (0%) ![]() |
QUOTE(presure2 @ Mar 6, 2056 - 99:22 PM) 440cc is gonna be on the big side for your application for a 7a, somthing in the 360cc range should be more than adequate this is what i went off of.....i turst him ![]() |
art, he's got an ST, not a GT.
ok i miss read ..........presure2 your my hero
This post has been edited by southwest2118: Mar 6, 2006 - 4:46 PM |
QUOTE(Supersprynt @ Mar 6, 2006 - 1:03 PM) [snapback]403376[/snapback] Noo..thats how your going to blow your engine. You cant add fuel with the SAFC, only take it away. The best thing you can do with this is add a fuel pressure regulator to add fuel, then use the SAFC to tune it properly. In addition, the stock fuel system of a 7a of 5s isnt enough for a turbo. So the injectors and a new fuel pump is necessary. The SAFC is not a substitute for the proper parts. erik, i believe you have that backwards. its remove fuel = advanceing timing adding fuel = retarding timing -------------------- Former Team 5SFTE pro member ;)
so what size is stock ?
you think i can get away with 6-8 psi whith 305cc?? This post has been edited by southwest2118: Mar 6, 2006 - 4:44 PM |
QUOTE(presure2 @ Mar 6, 2006 - 3:15 PM) [snapback]403457[/snapback] QUOTE(Supersprynt @ Mar 6, 2006 - 1:03 PM) [snapback]403376[/snapback] Noo..thats how your going to blow your engine. You cant add fuel with the SAFC, only take it away. The best thing you can do with this is add a fuel pressure regulator to add fuel, then use the SAFC to tune it properly. In addition, the stock fuel system of a 7a of 5s isnt enough for a turbo. So the injectors and a new fuel pump is necessary. The SAFC is not a substitute for the proper parts. erik, i believe you have that backwards. its remove fuel = advanceing timing adding fuel = retarding timing Thats not his concern tho the timing, he wants to add fuel for his turbo setup? I'm guessing and the SAFC alone isnt the way to go and I'm afraid he's going to grenade his engine. -------------------- |
QUOTE(presure2 @ Mar 6, 2006 - 3:13 PM) [snapback]403455[/snapback] art, he's got an ST, not a GT. i missed that part...lol -------------------- 15PSI - 30MPG - Megasquirt Tuned
ok i wired everthing like doc said i still have the stock injectors in so everthing is set at 0 ....it runs but i'ma go take it for a test drive.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) ![]() |
Let us know
![]() -Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
k car runs ok i think. but need to drive more to tell if theres a difference.
when i turn on the car all the knobs are green, when i hit like 1500 rpm the first knob(800 rpm) turns orange then the gets brighter red as rpm rises. Now i don't know any body thats had one of these so i don't know if thats normal? but if i had made this i would of had each knob turn red as the rpm reaches that setting. maybe its suppose to do that? maybe not? ![]() |
![]() ![]() ![]() ![]() This post has been edited by southwest2118: Mar 8, 2006 - 7:27 PM |
http://pages.sbcglobal.net/celica1/safc3.htm
read the last part...it should go red to the next knob....... wrong rpm wire.....doc i put the green wire to (a5) in the diagram? and if wanted to connect to (a18) theres no wire coming out? is it (a18) or (a17) ??? may be this would be easier.? ![]() This post has been edited by southwest2118: Mar 8, 2006 - 7:51 PM |
Yes, A5 or A18, A18 is a red wire right next to a white wire.
why dose a18 say its red but the wire goes nowhere?
ok i got it . i rewired it to a5 and it works. This post has been edited by southwest2118: Mar 8, 2006 - 11:24 PM |
Lo-Fi Version | Time is now: February 23rd, 2025 - 4:59 PM |
