Help clutch adjustment? |
Mar 5, 2006 - 4:01 PM |
Enthusiast Joined Jan 17, '06 From Wisconsin Currently Offline Reputation: 0 (0%) |
Ha guys just drove my 94 celica with the new centerforce clutch I installed. Well the clutch pedal doesn't disengage the clutch until the pedal is almost on the floor! So how do I adjust this?
-I see there is a threaded rod on the clutch pedal that I will lengthen but there is only a 1/4" left to lengthen the rod so I don't believe I'll gain much here! -I'll try bleeding the line even though it was never opened... -ANy other ideas???? -I am thinking of wellding a little extra metal onto the pushrod that is at the clutch end to get more length to work with....Is this called the master cylinder can't remeber the tech. term.... *I'll do this last if others don't help...... |
Mar 5, 2006 - 6:59 PM |
dont weld anything on
1st try a full adjustment. if that dosnt help you, they sell longer push rods for our cars. read this PDF, it will explain how to adjust it. http://www.celicatech.com/imagearchive/bgb...nual/clutch.pdf -------------------- 15PSI - 30MPG - Megasquirt Tuned
Mar 5, 2006 - 8:32 PM |
Enthusiast Joined Jan 6, '06 From Michigan Currently Offline Reputation: 0 (0%) |
didnt your centerforce clutch come with a adjustment sheet. i just got my clutch done about 2 weeks ago, and there was a sheet in there for adjustments. Maybe you can call canterforce, and ask them to send you that sheet.
Mar 6, 2006 - 12:01 AM |
Thanks guys I have that sheet and will look into it tomorrow. First thing I will do is bleed the system. However,
-were do you get a longer pushrod from as this is so far off I am sure I will need one. -Can you tell me how much longer this different push rod is? Or know someone who could tell me the length of one of the longer ones so I can compare with what I have??? Thanks..... |
Mar 6, 2006 - 7:46 AM |
www.twosrus.com
13.6@108MPH, 5SFTE Powered |
Mar 6, 2006 - 9:33 PM |
THanks for all the help guys I was able to screw the rod out on the clutch pedal to make it longer. I only had 1/4" to work with but that gave me a few inches more to use on the clutch pedal. So it looks like the clutch job was a success!!!!!
Mar 7, 2006 - 1:44 PM |
Enthusiast Joined Aug 18, '04 From Silverdale, WA Currently Offline Reputation: 0 (0%) |
For all those that are looking for the longer slave cylinder push rod here is the site. They also sell the shifter bushings.
http://www.speed-source.net/ |
Mar 7, 2006 - 4:48 PM |
QUOTE(bindertch @ Mar 7, 2006 - 1:44 PM) [snapback]403966[/snapback] For all those that are looking for the longer slave cylinder push rod here is the site. They also sell the shifter bushings. http://www.speed-source.net/ hmm i thought people replaced the push rod thats connected to the clutch pedal, and not the one thats on the slave cylinder ? -------------------- 15PSI - 30MPG - Megasquirt Tuned
Lo-Fi Version | Time is now: November 30th, 2024 - 9:50 AM |
