need help with my turn signal |
Mar 5, 2006 - 5:49 PM |
Enthusiast Joined Oct 10, '05 From NJ Currently Offline Reputation: 0 (0%) |
my turn signals both directions just stopped workin. i checked all the fuses and bulbs. theyre all ok. can you guyz help? by the way this is my first post. sorry if its bad.
Mar 5, 2006 - 5:59 PM |
Enthusiast Joined Jan 10, '04 From Shoreline, WA Currently Offline Reputation: 4 (100%) |
hmm. maybe a short in the wires, I would trace em as far back as you can. although to short the wires without blowing a fuse would be hard I think.
make sure the wires are connected good at the bulb housing, sometimes they get bent around and yanked where there still in but the connetact is lost. dubble check fueses and bulbs. -------------------- |
Mar 5, 2006 - 6:27 PM |
Enthusiast Joined Oct 27, '05 From Olympia, Washington Currently Offline Reputation: 1 (100%) |
Make sure the connection in the back of your hazard button is connected properly...If that isnt connected right the turn signals wont work...
-------------------- !!KANER!!
Mar 5, 2006 - 8:21 PM |
Enthusiast Joined Feb 25, '04 From Fairfield, CA Currently Offline Reputation: 0 (0%) |
Sorry, I know this is going to be a crappy answer because it's hard to describe, but there's this little relay that can go bad. With mine it was a slow degradation. The clicking got slower and slower and sometimes it would freeze in the on or off position. Finally it stopped entirely. The relay is located on a fuse panel under the driver side dash above the foot rest for your left foot. You can get a replacement from any auto parts store. It's about the size of an ice cube and you just pull the old one out and plug the new one in.
Mar 5, 2006 - 9:54 PM |
Enthusiast Joined Jun 19, '05 From Nebraska Currently Offline Reputation: 4 (100%) |
ya, lol. its called the flasher. It says flasher right on it
-------------------- Teh Celica sleeps for Winter '06. Suspension overhaul begins........
Mar 6, 2006 - 5:06 PM |
thanks i ordered a 4X flasher to replace it thanks alot everyone again
Mar 6, 2006 - 5:32 PM |
hey kinda off topic but...in your profile it say you have a GT-S swap. What is a GT-S swap ?
Lo-Fi Version | Time is now: November 24th, 2024 - 10:04 PM |
