> shorter sway bar, any for our cars?
post Mar 5, 2006 - 8:41 PM
FSX_Celica94GT
Joined Nov 26, '03
From Texas
anyone kno if there are any sway bars out there that are shorter than the factory one?
post Mar 5, 2006 - 9:31 PM
How can you have a shorter sway bar? It needs to connect to th endlinks...
post Mar 5, 2006 - 9:37 PM
you want thicker....not shorter
suspension techniques
post Mar 5, 2006 - 9:53 PM
FSX_Celica94GT
Joined Nov 26, '03
From Texas
well, the thing is, my sway bar links are in a bind, and my mechanic said if its possible to get a shorter sway bar, then it might fix the problem. idk what the hell is wrong w/ my sway bar and links, but they're knocking against the frame whenever i go over a bump and i cant seem to find any solution to this other than a different sway bar maybe.
post Mar 5, 2006 - 9:54 PM
how are your swaybars hitting frame?
they would literally have to go up about 12" or more
post Mar 5, 2006 - 10:14 PM
Your sway bar is ontop of your crossmember, if thats hitting anything you have a suspension problem.
This post has been edited by Supersprynt: Mar 5, 2006 - 10:41 PM
post Mar 5, 2006 - 10:21 PM
jgreening
Joined Jan 17, '04
From Illinois
QUOTE(playr158 @ Mar 5, 2006 - 8:54 PM) [snapback]403089[/snapback]
12 inches? Try about 1" clearance on a lowered car.
post Mar 5, 2006 - 10:42 PM
in the front i could see them being about an inch..i've been looking through all my build pics and it seams they are just outside the frame rail into the wheel well by a little bit but cause of camera angles it is hard to see..thanks for the ammendment jay..(although it doesn't say he's lowered in his profile)
but i guess they might have gotten bent? or have a control arm problem?
possible to get a picture of where is connecting with the frame?
This post has been edited by playr158: Mar 5, 2006 - 10:42 PM
post Mar 6, 2006 - 1:25 AM
jayi12-15psi
Joined Jan 9, '03
From St. Louis
I would never want to take the sway bar off ever again after the pain I went through last night with the endlinks.
post Mar 9, 2006 - 3:30 PM
GT4WRC
Joined Mar 17, '05
From Auckland, New Zealand
Are the links on the correct way round? If not, then they are liable to hit the subframe. Try turning them round so the bolt passes through the end of the bar on the other side of it. ie rotate the link through 180 deg of its vertical axis.
Gary
1994 ST205 Celica GT-FOUR Group A WRC - running in new engine
1993 Rover 220 GTi tarmac rally car (under construction) 3SGE power here we come....
GT-Four spec list
Lo-Fi Version Time is now: January 10th, 2025 - 10:45 AM
