> 2" Drop?
post Mar 6, 2006 - 6:46 AM
Celiracer18
Joined Aug 23, '05
From Princeton, Minnesota
Would a 2" Drop work with stock rims + tires or should i just get some rims and springs at the same time?
-Brian
post Mar 6, 2006 - 8:12 AM
CelicaZR
Joined Mar 25, '05
From Sydney, Australia
6GC 4 Life Baby!!!
post Mar 6, 2006 - 8:20 AM
NaKeD
Joined Nov 21, '05
From Australia, Melb
IMO you should wait to get the rims and springs at the same time, i don't know about technical issues
but it would look silly with stock rims...
do a complete make over get both at once
NaKeD
post Mar 6, 2006 - 10:38 AM
Jen
Joined Jul 14, '03
From Jacksonville, FL
Well I had the Intrax (1.75") springs on stock wheels.. and it looked nice.
YoungSurvival.Org
post Mar 6, 2006 - 10:42 AM
a 2" drop on stock wheels will be fine just remember driveways and speed bumps must be taken at an angle
post Mar 7, 2006 - 3:24 AM
CelicaZR
Joined Mar 25, '05
You dont want to drop it now.
What happens when you buy your new wheels,
you might have to change the height again.
6GC 4 Life Baby!!!
post Mar 7, 2006 - 3:37 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
I would wait until you have the wheels you want, then lower it.
Off Topic, but when I get my Coilovers installed, what height would you all recommend?
EDIT: with 17" wheels
This post has been edited by 95CelicaST: Mar 7, 2006 - 3:37 AM
**** Photobucket
post Mar 7, 2006 - 8:49 AM
Guest_TurbO_*
2 inch drop...im just not feeling the 1.5 inch drop...i dont know but its just me...for me 2 inch in front and 1.8 in the rear makes the car look nice...my cuz had his like that stock with 17x17.5 and hell it looked great...i have a friend who has a 1.5 inch drop and um...looked stock/still pretty high...i dont know but i've always liked the celicas low...
post Mar 7, 2006 - 8:55 PM
Celiracer18
Joined Aug 23, '05
GODD i want some coilovers but just cant afford them
then all my problems/questions would be solved
Edit: correct me if im wrong but i heard the ground control coilovers didnt ride too nice and that its kind of a waste
This post has been edited by Celiracer18: Mar 7, 2006 - 8:57 PM
-Brian
post Mar 8, 2006 - 12:37 PM
95CelicaST
Joined Feb 5, '05
They're ride is suposed to be stiff. If you get adjustable shocks you might be able to negate the hard spring oscilation.
**** Photobucket
post Mar 8, 2006 - 7:28 PM
madmods
Joined Mar 19, '04
From Scottsdale, Az
QUOTE(Celiracer18 @ Mar 6, 2006 - 11:46 AM) [snapback]403268[/snapback]
Go for it. I personally recommend coilovers over springs due to the adjustability. Even with stock rims
it should look better.
QUOTE(95CelicaST @ Mar 7, 2006 - 8:37 AM) [snapback]403828[/snapback]
Play with it. I had my car way low at one time, and cracked everything. I lifted it up a bit and everything is fine. I stay take driveways at angles.
post Mar 9, 2006 - 6:34 PM
yyet
Joined Jan 6, '06
From Oahu, Hawaii
I got a question too. I'm planning to keep my stock rims/tires, no body kit or sideskirts, how large a drop would look nice??? And what's like the good brands of springs? Oh yeah, whats the diff. between coilovers and drop springs???
Thanks
Yet
post Mar 10, 2006 - 12:25 AM
hitcachi
Joined Jun 19, '05
From Nebraska
normally i would say research and dont be lazy.........but im feeling nice. Coilovers=ajustable up to 4in or 3in drop. Lowering springs permanet drop. But the ride that coilovers provide is............."up to personal opinion" They can ride like crap or not to bad. But brand quality means more then anything really. I prefer springs personally. I am going to be putting on Intrax springs which are very good quality along with Teins and Eibach. Just search the parts database is going to be your best bet.
post Mar 11, 2006 - 7:26 PM
tovejas
Joined Nov 22, '05
From Mississauga, Ontario
does anyone have the tanabe df210 (2"-2 1/2" drop) on their cars? just curious how nice the drop would look? kinda want to see them on stock rims........thanks
post Mar 12, 2006 - 2:49 AM
purplegt4
Joined Feb 7, '03
From Northern Virginia
Technically speaking from TRD's point of view (TRD Suspension kit), the ride height they engineered for best handling on the street would be a 35mm drop in the front and 15mm drop at the rear. For circuit purposes, TRD recommends a 50mm drop in the front and a 30mm drop at the rear. This information is for a AT200/ST20x
TRD Suspension Kit for Circuit
post Mar 12, 2006 - 2:54 AM
purplegt4
Joined Feb 7, '03
so yea in other words...your 2" drop will be for circuit in the front and disFU*Ktional in the rear. I wouldn't lower the rear anywhere past 1.25". Keep it (rear) in the range of .5" to 1.25".
Lo-Fi Version Time is now: January 8th, 2025 - 9:56 PM
