![]() Enthusiast ![]() ![]() Joined Jan 13, '06 Currently Offline Reputation: 0 (0%) ![]() |
ok today I got my cheap egay filter..
![]() And my atp restrictor and t3 oil outlet gasket. the restrictor is weak i can only get the 1/8 npt male in like 15% of the way in then it feels like I'm about to cross thread. i emailed them and ...... ![]() last week i spent like $30 at summit and all i got was this pimpin hat. ![]() .....i got my 24" -3an line and some -3an to 1/8 npt adapters too. ![]() |
OK this weekend i'ma start intalling the turbo.
By friday I should have bov, s-afc, and injectors. |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) ![]() |
You can't tighten NPT threads all the way, that's how they seal, they're tapered. Once they're that tight, you'll all set.
-Doc This post has been edited by Dr_Tweak: Mar 8, 2006 - 3:29 AM -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
thats true but i got like 5 threads in? i talked to atp and they should be sending me another.
It won't be any different
![]() -Doc This post has been edited by Dr_Tweak: Mar 8, 2006 - 5:11 AM -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
hey doc what do you think about the restictor
causing foaming? at 60 psi that oil is going through that little hole pretty fast right? and you think i should put it at the TEE or right on the turbo...dose it matter? -3an with a restrictor shouldn't be a problem right.? |
Trouble is, whether or not you need it is dependant on quite a few factors. Some people use them and blow thier turbos, some people don't use then and blow their turbos.
Well, what I typically do is run a 1/8" line (3AN) with no restrictor, and a nice big, straight return line. If the turbo is still getting too much oil, then I'll try the restrictor. -Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
QUOTE(Dr_Tweak @ Mar 8, 2006 - 5:13 AM) [snapback]404468[/snapback] Trouble is, whether or not you need it is dependant on quite a few factors. Some people use them and blow thier turbos, some people don't use then and blow their turbos. -Doc WTF ![]() ------------------------------------------------------------- well if the turbo is getting to much oil...when you find out won't it be to late? blown seals? i get like 60psi on start up and throttle This post has been edited by southwest2118: Mar 8, 2006 - 6:24 AM |
Depends on the engine and the turbo, along with the size of the oil feed and return lines... I don't know of any OEM turbo engines that have restrictors intalled.
Lo-Fi Version | Time is now: February 23rd, 2025 - 1:41 PM |
