maximum rim size for a ST202, 98' SSIII?, biggest without the problems? |
Mar 7, 2006 - 6:04 AM |
Enthusiast Joined Mar 4, '06 Currently Offline Reputation: 0 (0%) |
Hey all,
I've tried a search for this and it doesn't appear to have been a topic about it. Has anyone tried to have a 19x8 rim on their celica? I have a 98' SSIII. What tyre profiles have you fitted with your rims? Any problems? I'm thinking about getting a set of 19x8. Any replies would be greatly appreciated. thanks |
Mar 7, 2006 - 6:29 AM |
Enthusiast Joined Mar 25, '05 From Sydney, Australia Currently Offline Reputation: 0 (0%) |
I know this is possible on a 6gc.
ice23q has this on his car. You'll need a very low profile tires and offset for the wheels. -------------------- 98 ST204 ZR - Black Beauty - Roaming the streets of Sydney 73 TA22 LT - Tiffany Blue - Mint Classic Weekend Cruiser 75 TA22 LT - Snow White - Mint Classic Weekend Cruiser 77 RA28 LT - Flubber Green - Mint Classic Weekend Cruiser 94 MX-5 NA8 Clubman - Red Racer - Looking for corners WIP Project: 69 RT40 Corona, 2nd WIP Project: 66 RT40 1600s Corona 86 Corona RT142 - Daily Driver 6GC 4 Life Baby!!! |
Mar 7, 2006 - 9:22 AM |
Enthusiast Joined Feb 3, '06 From Czech Republic (Europe) Currently Offline Reputation: 56 (100%) |
IMHO it's crazy. You'll need tire xxx/30 R19, that's too low tire for common streets (If you use xxx/35 R19 your car will have higher clearance height)
-------------------- No more replicas... This is evolution... This is SS-four :)
________[Featured Celica of 6gc.net @ 2010]_________ |
Mar 8, 2006 - 5:39 PM |
Enthusiast Joined Jun 6, '05 From Texas/Hawaii Currently Offline Reputation: 0 (0%) |
ive see te 19 inch done before but boy drivin it sure is hard the highest you would prob want to go with is 18 with a 30-35 pro or above. most people go with 17's
-------------------- I gotz 2 things my celi and a dream, the prob is commin up with the thrid one...
Mar 8, 2006 - 5:42 PM |
Enthusiast Joined Oct 5, '05 From NE Currently Offline Reputation: 6 (100%) |
In a magazine i've seen a guy with our celica with 20' rims all around. And was drivable. But he had the same set of rims at 22's that he used for shows only (couldn't turn)
Mar 10, 2006 - 4:41 PM |
QUOTE(celiracer @ Mar 8, 2006 - 5:42 PM) [snapback]404754[/snapback] In a magazine i've seen a guy with our celica with 20' rims all around. And was drivable. But he had the same set of rims at 22's that he used for shows only (couldn't turn) dang 22" wow i think that would look really funny. heh i bet that he has a nice rims with a car on it. the celi is way toosmall for 22s i imagine that it would be all rims with a little bit of car on top -------------------- I gotz 2 things my celi and a dream, the prob is commin up with the thrid one...
Mar 10, 2006 - 7:40 PM |
Enthusiast Joined Sep 12, '03 From Portland , Oregon , United States Currently Offline Reputation: -1 (33%) |
19"x8"
KYB-GR2 Struts - Tein TechS springs about 1.5" drop 225/35-19 Toyo Proxies. No rubbing at all, I think ill probley get 19x9 front and 19x10 rear next time around tho. DTE This post has been edited by Clipsetuner: Mar 10, 2006 - 7:42 PM -------------------- I am a thief.
do not buy anything from me. |
Mar 10, 2006 - 8:03 PM |
Ya it looked really funny. Way to much rim for the celi..
Mar 10, 2006 - 11:32 PM |
Enthusiast Joined Apr 30, '04 From Thailand Currently Offline Reputation: 0 (0%) |
QUOTE(Cubix @ Mar 7, 2006 - 6:04 PM) [snapback]403843[/snapback] Hey all, I've tried a search for this and it doesn't appear to have been a topic about it. Has anyone tried to have a 19x8 rim on their celica? I have a 98' SSIII. What tyre profiles have you fitted with your rims? Any problems? I'm thinking about getting a set of 19x8. Any replies would be greatly appreciated. thanks 19"*8 offset 35-30 would be perfect. I used to fit these before my ride got widebody. currently I got 19"x 8.5 offset -9 front and 9.5 offset -3 rear. |
Mar 10, 2006 - 11:37 PM |
QUOTE(celiracer @ Mar 9, 2006 - 5:42 AM) [snapback]404754[/snapback] In a magazine i've seen a guy with our celica with 20' rims all around. And was drivable. But he had the same set of rims at 22's that he used for shows only (couldn't turn) 20" fitment, you do need to carefully choose the offset and tyre profile will be as 225/30 or 215/35 which too low and hardly drive. especially in the front where the tyre will be rub the inner side of underfender area.. For safe, maximum you can go would be 19"....I have been using it over a year and no problem with it.. |
Mar 10, 2006 - 11:48 PM |
Enthusiast Joined Feb 10, '03 From warren, ohio Currently Offline Reputation: 0 (0%) |
I just put on my rims they are 19x8 with a 40mm offset. My tires are toyo 225/35/19. Ihave kyb struts and groung control coilovers its lowered 4 inches. They fit just fine in the wheelwell no rubbing and i didnt have to roll my fenders and i thought i would. I did get cusco camber adjustable uppermounts for the front. I would like to find something for the rear camber though if anyone has any suggestions.
Mar 11, 2006 - 12:16 AM |
Enthusiast Joined May 24, '03 From Andrews TX Currently Offline Reputation: 1 (100%) |
I have some AXIS 19x8.5 rims (35mm offset) with Toyo T1-S 235/35/19 with Koni(non-adj.) and tein S-techs
ALOT of people were telling me to do a 38mm offset but AXIS recommended the 35mm and it is a tight fit. the only problem that I have had is that if I hit a dip hard(very hard) the pass.rear tire would scrape on the inner side of the fender very breifly, only happened 2 or 3 times. AS far as drivability on the way home after I took off my 17's I had to go down a rough road and my only thought was "what the &$^* did I do?" because the ride was so rough compared to my last tire/wheel setup. BUT by the next week I was completely used to it and totally love my 19's I also plan on going with a wider tire soon I am going to try a 245/35/19 toyo T1-R but with the drop on my car it will be very close to the fender if it is wider- but if I get brave I will try a 255/30/19...we'll see As for pics I think there might be some in my profile, if not I will see if I can put some there -------------------- If anyone is missing NASCAR and it's not on Speed Channel, take a fistful of Skittles, throw them in the toilet and hit the flush handle. Instant NASCAR!!!
Lo-Fi Version | Time is now: January 10th, 2025 - 8:18 AM |
