![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '03 From Rockland NY Currently Offline Reputation: 15 (100%) ![]() |
You need mounts and brackets from a GT. All four GT brackets and three GT mounts. You can use your ST rear mount.
-------------------- ![]() I will return one day. |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 28, '05 From Redondo Beach, CA Currently Offline Reputation: 86 (100%) ![]() |
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Hollywood, MD Currently Offline Reputation: 6 (100%) ![]() |
junkyards and car-part.com dont come up with engine mounts
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 29, '03 Currently Offline Reputation: 0 (0%) ![]() |
You can buy brand new mounts here for a lot cheaper than Dealer Pricing.
Home Page: http://www.trademotion.com/partlocator/ind...840&catalogid=0 Mounts Selected: http://www.trademotion.com/partlocator/ind...995&catalogid=1 |
mmk well i stand corrected i must have miss understood sumthing down the line good stuff
ordered the front and rear mounts overnight from toyota they will be here at 7:30 tomorrow morning
![]() looks like this swap is possible after all ![]() its crunch time boys edit: 142$ i didnt have though ![]() This post has been edited by brianforster: Mar 23, 2006 - 12:10 PM |
![]() Enthusiast ![]() ![]() ![]() Joined Feb 15, '05 From Frederick, Maryland Currently Offline Reputation: 8 (75%) ![]() |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 12, '05 From Texas Currently Offline Reputation: 59 (100%) ![]() |
Just to warn you, more random stuff will come up...and if you don't have $142, you maybe should not be swapping
![]() ...but good luck on the swap, and keep us posted. ~snap -------------------- Past: V6 Swapped 6G Celica, E46 BMW M3, Jeep Wrangler TJ
Current: 850rwhp C6 Corvette Grandsport, Gen1 6.2L Ford Raptor |
i know snapshot, i have an emergency credit card for situations like the 142$, and ill pay it off myself as well, i just mean its an unexpected 142$, not that im literally going to bounce a check or anythign
QUOTE(brianforster @ Mar 23, 2006 - 12:16 PM) [snapback]411911[/snapback] i know snapshot, i have an emergency credit card for situations like the 142$, and ill pay it off myself as well, i just mean its an unexpected 142$, not that im literally going to bounce a check or anythign ![]() -------------------- Past: V6 Swapped 6G Celica, E46 BMW M3, Jeep Wrangler TJ
ok update, i removed the engine harness, hopefully to solder the connections tonight.
but a few things i have serious doubts in my ability to put the harness back one of my fuel injectors (or so im asuming) plugs , a wire got ripped, but like RIGHT at the connector, so no idea what im gonna do though and one of the middle plugs, like, its got two prongs and two wholes, but in one of the wholes is metal like you usually see and one is missing. i didnt hear anything break, nor did i see the prong, im not even entirely sure its possible for the piece im talking about to break, but it looks like it comes from the fuel rail into the throttle body |
the only one i i know of is the tps=throttle body?
Enthusiast ![]() ![]() ![]() ![]() Joined Jul 10, '05 From Monroe, WA Currently Offline Reputation: 6 (100%) ![]() |
not to put you down or nag, but you should have pulled the harness first thing and maybe taken that inside and work on that once the sun goes down outside you go in and work on the wires. would have been more time effective to reach your said goal.
![]() -------------------- 94' ST Coupe - 5sfe Motor swap and brake swap.
Show us a pic of this plug
![]() Enthusiast ![]() ![]() Joined Jun 21, '05 From New york Currently Offline Reputation: 1 (100%) ![]() |
I am glad you have the mounts taken care of...but wiring is going to take a little while i would assume. But hope you figure out what that "prong" is or was!! Good luck again...little stuff is always what kills a deadline! Nothing ever seems to go right when you actually need it too!
Bigal -------------------- 1994 celica GT.....3sgte in a month! all helpers are welcome!!! i live in Plattsburgh, NY.
the motor is in, and 3 mounts are bolted down, with the 4th ready and lined up for drilling tomorrow.
oh yeah anyone interested in keeping the power steering on their ST for the swap without sourcing too many parts check it out: i got a power steering resevoir from a wrecked GT, and i mounted it in the stock location. then i took the return line from the 7afe (remember how it unnecessarily looped back on itself?) and cut it right behind the resevoir, and attatched the return line, voila, it all mounts in the same positions as well, you just have to get: gt resevoir, gt high pressure line, and a long enough piece from the gt resevoir return line to attatch to your stock (hard line) return line. tomorrow, boiled down to a simple phrase, is "plug and play". although i do not expect to get the motor running tomorrow, im just saying that the connections should be made. although i do know that i will need to take pics and ask questions here as there are some plugs, vacuum hoses, etc, that i do not know where to put ![]() |
all mounts are bolted down and most of the electrical stuff is done, now i just have to connect all the hoses galore.
friends are done helping for the weekend though, so its just me, im gonna try and get some of the interior finished, its just kind of depressing because tomorrow i go back to school and wont be able to work on the car in my free time. id say theres a solid day of work to do, if i had someone here that knew the 3sgte well, with just me, who knows how long it will take. there are hoses that arent labeled everywhere. bit depressed right now, but ill get over it. edit: im gonna try and get some pics tonight of stuff im not sure where to mount, like the injector resistor pack, and hoses i cant find leads for. This post has been edited by brianforster: Mar 25, 2006 - 1:46 PM |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 12, '02 From Baltimore, MD Currently Offline Reputation: 1 (100%) ![]() |
Here are a couple pics I took today..
More work was done after those pics were taken tho, so its a little better looking than that ![]() -------------------- ![]() |
good work man
i feel like im watching Extreme Makeover: Celica Edition. lol -------------------- 15PSI - 30MPG - Megasquirt Tuned
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 12, '02 From Webster Ma. Currently Offline Reputation: 1 (100%) ![]() |
sweet deal man
Lo-Fi Version | Time is now: February 23rd, 2025 - 1:16 PM |
