> RPM dropping to like 500
post Mar 7, 2006 - 7:01 PM
southwest2118
Joined Jan 13, '06
when i turn on my A/C the car is supposed to kick
up the rpm. but for the past 2 months at idle the rpm
drops to like 500 and the car starts shaking.??
its a 7a-fe 95 corolla.
post Mar 7, 2006 - 8:02 PM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
Mine does this too, then levels out. When I turn it off, the rpm goes up, but then levels off.
Live Free, Be Happy
post Mar 7, 2006 - 8:04 PM
southwest2118
Joined Jan 13, '06
why
dose it have something to do with the A/C idel up valve? top center of engine
post Mar 7, 2006 - 8:19 PM
hitcachi
Joined Jun 19, '05
From Nebraska
No it has to deal with the fact that we have relativly small engines and AC condenser demands quite a bit of power to operate.
This post has been edited by hitcachi: Mar 7, 2006 - 8:19 PM
post Mar 7, 2006 - 8:24 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
its the IAC...clean it or get a new one.
post Mar 7, 2006 - 10:17 PM
Jdog1385
Joined Apr 14, '03
From Long Island, N.Y.
but i would seriously check your pully's, alternator and also the a/c unit. but there probably is nothing you can do about it. small motors, big underdrive
post Mar 8, 2006 - 2:48 AM
southwest2118
Joined Jan 13, '06
**** i think i figured it out.... i teed the A/C idel up valve vac line for my boost gauge? i think thats what it is. ya and the gauge its been acting up
post Mar 8, 2006 - 12:03 PM
its the A/C idle up valve.
post Mar 9, 2006 - 9:55 AM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
If your engine is not ideling well, there is a screw that sits on your Throttle butterfly. Take it out or screw it in some more so that more air goes into the manifold chamber. That will raise the RPM by a notch.
post Mar 9, 2006 - 10:09 AM
southwest2118
Joined Jan 13, '06
its fine with out a/c. only when the ac comes on.. also noticed my radiator fan stoped working. when it gets hot theres power going to it but ...the fans dead?
post Mar 9, 2006 - 10:11 AM
LewFX
Joined Jan 28, '05
QUOTE(southwest2118 @ Mar 9, 2006 - 10:09 AM) [snapback]405061[/snapback]
IAC!!!!!!!
post Apr 5, 2006 - 5:13 PM
tceligt
Joined Sep 7, '05
From Ensenada, Baja California, Mexico
LewFX, you wrote that could be the IAC valve, this valve is also know like ISC idle speed control?
Is the one in the throttle body? here a picture IPB Image
Lo-Fi Version Time is now: December 11th, 2024 - 9:57 PM
