> Help firing order 2.2liter?
post Mar 7, 2006 - 10:21 PM
bdog_v
Joined Jan 17, '06
From Wisconsin
Hello I went to replace my spark plug wires on my 94 celica 2.2 liter and have found a problem between my chilton manual and how my spark plug wires were set up?
-The chilton manual states for 5s-fe engine 4-3-2-1 , now #4 cylinder is on the passenger side in their manual.
-However on my car the #4 cylinder by the passenger side according to the chilton manual, was reversed and on the driver side, so on my car the cylinders went 1-2-3-4 with #4 being on the driver side, the exact opposite of the chilton manual, and the spark plug wires ran to the appropriate number on the distributor cap.
-So is it possible to reverse the wiring and the car will run o.k. or did the chilton manual make a mistake???
-I am doing an overall tuneup on the car and will be doing timing so I, need to know what cylinder to time off of?????
-Has anyone ran into this issue? What is the correct cylinder order??? THanks...
post Mar 7, 2006 - 11:49 PM
i think you are confusing firing order with the numbers that are on your spark plug wires. firing order, just means the order the spark plugs fire in.... but dont pay any attention to this. just hook up your wires 1234 from left to right. do the same thing when looking at the distributor cap.
if you put the wires in the wrong order, the car will run funny.
post Mar 8, 2006 - 12:19 AM
bdog_v
Joined Jan 17, '06
From Wisconsin
Well I guess I am more concerned with wether the #4 cylinder should be the outside cylinder on the passenger side of the car or the driver side? Or is this irrelevant ?
Cylinders
Passenger side car 1-2-3-4 driver side car or
4-3-2-1
-The chilton manual shows the second example above and my car is wired like the first.
-I don't believe I should've used the term firing order. That was misleading. I am concerned with the question above. Any opinion on that????
-Oh it seems to run fine as it is now.
This post has been edited by bdog_v: Mar 8, 2006 - 12:20 AM
post Mar 8, 2006 - 2:13 AM
stand in front of the motor... and count from left to right. number 1 is passengers side and 4 is drivers
post Mar 8, 2006 - 12:14 PM
bdog_v
Joined Jan 17, '06
From Wisconsin
Great that is exactly what I needed to know! The chilton manual made a boo, boo!!!!!! Thanks...
post Mar 9, 2006 - 9:53 AM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
Firing order = 1-4, 2-3.
It goes from left to right from the pass. side to the drivers side.
Seriously tho, it could be 4-1, 3-2 and it does not matter which one goes first such as the # 1 or the # 4 cylinder, cause both pistons come up at the same time. tongue.gif
post Mar 9, 2006 - 7:10 PM
mikew04
Joined Feb 19, '04
From austin tx
QUOTE(soulshadow @ Mar 9, 2006 - 9:53 AM) [snapback]405053[/snapback]
No. You forgot about fuel and air. They might both be comin up at the same time, but one is in the compression stage and the other is evacuating the exhaust gas. So- valve openings are different between the two. Injectors fire at different times as well.
Lo-Fi Version Time is now: January 12th, 2025 - 1:50 PM
