Broken Exhaust Manifold Bolt, What Can I Do? |
Mar 9, 2006 - 11:14 PM |
Enthusiast Joined Sep 26, '04 From Sacramento, California Currently Offline Reputation: 4 (100%) |
Today I was looking around my engine and found that there was a exhaust manifold nut missing. So I looked closely and realized that half of the bolt was snapped off. What can I do to fix it? Is there replacement studs that I can use? If so how would I take off the broken half? Thanks
This post has been edited by TRD-ST204: Mar 9, 2006 - 11:14 PM |
Mar 11, 2006 - 12:16 AM |
Help! Anyone?
Mar 11, 2006 - 12:20 AM |
toyota will sell you a new stud. should be able to take the old one out with craftsman bolt extractors.
Mar 11, 2006 - 12:43 AM |
If you can't get it out by hammering it, you'll have to drill it out. When I say hammer, what you do is find a little edge were you can tap the screw in a counter clockwish motion. Drilling it out and retapping are a little bit of an ordeal. If you get so far as drilling it, make sure you tap it with the right size by taking out another bolt and matching the patterns.
Mar 11, 2006 - 8:28 AM |
if the stud is sticking out of the head at all, they normally come out pretty easy.
best thing to do is use 2 bolts if you can get them on, or craftsman also makes a stud extractor that works well. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Mar 11, 2006 - 10:45 AM |
Enthusiast Joined Jan 26, '05 From Ashville, Ohio Currently Offline Reputation: 2 (100%) |
if all eles fails i have the whole exhaust manifold for sale with all the bolts and nutz i have a posting with pics
Mar 11, 2006 - 11:44 PM |
Thanks, I'll try to get it out tomorrow.
Mar 13, 2006 - 12:41 AM |
Enthusiast Joined Mar 21, '04 From Oceanside Currently Offline Reputation: 2 (100%) |
When mine broke, I had to drill the broken stud because it was about three threads inside the head. I drilled it and tried to use and easy out. No luck! Eventually had to drill out the old bolt and tap a larger hole. I was told to find a stud that had two different sizes to it, but ended up using a heli coil. (I am not sure if I spelt that right). I placed it in the one size larger hole and then placed a stud that was the same size as the rest of the stock ones. That was four months ago and seems to be holding fine.
Mar 13, 2006 - 12:55 AM |
Enthusiast Joined Feb 7, '03 From Northern Virginia Currently Offline Reputation: 23 (100%) |
whatever u do dont use a gator-grip LMAO
as seen on tv BS |
Mar 13, 2006 - 1:33 AM |
Enthusiast Joined Jun 19, '05 From Nebraska Currently Offline Reputation: 4 (100%) |
Just to be safe, why is the bolt broken off? Does your pipe bend down pretty far to the ground before it goes up under the crossmember? Has is bottomed out right there and possibly casue the pipe to ripple up and crack a bolt. Check the manifold closely just to be safe.
-------------------- Teh Celica sleeps for Winter '06. Suspension overhaul begins........
Mar 13, 2006 - 7:32 AM |
Enthusiast Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) |
QUOTE(Green_MachToy @ Mar 13, 2006 - 5:41 AM) [snapback]406827[/snapback] When mine broke, I had to drill the broken stud because it was about three threads inside the head. I drilled it and tried to use and easy out. No luck! Eventually had to drill out the old bolt and tap a larger hole. I was told to find a stud that had two different sizes to it, but ended up using a heli coil. (I am not sure if I spelt that right). I placed it in the one size larger hole and then placed a stud that was the same size as the rest of the stock ones. That was four months ago and seems to be holding fine. This is technically the best way to make this kind of repair, a helicoil is actually stronger than the original thread. -Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Lo-Fi Version | Time is now: January 9th, 2025 - 2:09 AM |
