> 5S-fe, worth making a good natural aspired engine
post Mar 13, 2006 - 12:06 AM
ponyboy
Joined Mar 24, '04
From seneca falls
Hey i was wondering, i have a 5s-fe engine in my car, is it worth it to make it a good nautually aspired enigine or should i just save up for a 3s-gte. I can do all the engine work myself i am a toyota mechanic. I was just wondering from other people if they thought i should go all out with this engine or just do the the swap. Any thoughts would be appreciated.
post Mar 13, 2006 - 12:12 AM
save up. Theres no real potential in a n/a 5sfe.
post Mar 13, 2006 - 12:29 AM
j0e_p3t
Joined Dec 8, '05
From torrance/carson, ca
definitely swap
post Mar 13, 2006 - 2:38 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
i'll agree thats there not alot you can do NA. if your car has an adjustable distributor you can advance the timing a little for a small increase in torque and a shift in the power band to the mid/lower rpm range. its not a large increase and you'll want to run a slightly higher octane fuel after you do this.
another possibility is to get NA tuned with a safc or similar device, that with a header could pickup a few hp/tq in addition to the timing.
post Mar 13, 2006 - 5:05 PM
BLACKcelicaGT
Joined Sep 20, '05
From Hermitage, Pennsylvania
http://www.importperformanceparts.net/impo...pek-toyota.html
post Mar 13, 2006 - 5:38 PM
Rayme
Joined Feb 18, '06
From NB, Canada
a guy on celicatech once tried to built an all-motor 5s-fe, results were very disapointing. The head design just doesn't flow enough I heard.
-Rémy
02 SiR, 08 250R
post Mar 14, 2006 - 10:21 PM
syaoran60085
Joined Mar 15, '05
From Gurnee,Illinois
i would swap it...even i have 5s-fe engine with ram intake in it but add little power to it...plus it's an economy engine so definite a swap for you.
post Mar 14, 2006 - 10:27 PM
Bitter
Joined Mar 11, '06
theres always the hybrid 5s-gte or whatever. 3s head on a 5s block to make a 2.2L turbo motor.
post Mar 14, 2006 - 10:31 PM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
Go with a 3rd generation 3sge. That's a good motor for a NA build. 5sfe can be a fun little toy, but it will never be a serious motor. I'm working on some things right now. Check my profile for my mods, I still can't outrun anyone on a strate strech. But, if you want a NA motor, like me, strate stretch isn't what you care about.
Live Free, Be Happy
post Mar 14, 2006 - 11:11 PM
celicaboston1983
Joined Mar 20, '04
off topic ponyboy u from ma?
post Mar 15, 2006 - 8:41 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
The 5SFE only does what it does,
makes lots of torque down low, at the top it just chugs,
you cannot change that, it's simply the way
for +displacement 4 bangers hurt horsepower's displays.
not can be done to change it... it's gay.
How to make horsepower out of a four,
simply put, put the pedal to the floor.
what does this mean, why you says what you says?
Simple, I answer, horsepower needs revs.
Although much torque the 5SFE has, can't eat your cake then take it to bed.
post Mar 15, 2006 - 9:09 PM
Rayme
Joined Feb 18, '06
From NB, Canada
QUOTE(Bigmeanbulldog55 @ Mar 14, 2006 - 11:31 PM) [snapback]407742[/snapback]
EDIT : nevermind, I miss-read what you wrote laugh.gif
This post has been edited by Rayme: Mar 15, 2006 - 9:10 PM
-Rémy
02 SiR, 08 250R
post Mar 15, 2006 - 9:32 PM
burneeed
Joined Dec 18, '05
From BANNED
why na youll get nowhere. Well it depends on what you want to do. Youll end up spending alot more on an na setup than you would with a turbo setup and get better results... also depending on what you want. 5sfe makes low end power but once it gets to about 5k rpms it just craps it self. Its an economy motor.....
BANNED!
post Mar 15, 2006 - 9:51 PM
Bitter
Joined Mar 11, '06
hasnt there been an issue with the 3s blocks cracking between cyl 2/3 due to the water in the small passage between the 2 boiling and that one spot getting too hot? i remember there was a thread about that on mr2oc board. i think the solution was a 2nd electric pump to increase flow and/or a higher PSI cooling system.
post Mar 17, 2006 - 7:08 PM
ponyboy
Joined Mar 24, '04
From seneca falls
QUOTE(celicaboston1983 @ Mar 15, 2006 - 4:11 AM) [snapback]407779[/snapback]
No i am not i am from new york. Upstate near lake ontario
post Mar 18, 2006 - 2:30 AM
pandakid
Joined Feb 12, '06
From Fresno CA
who would you pass smog with the 3s motor?
Lo-Fi Version Time is now: February 22nd, 2025 - 2:20 AM
