Enthusiast ![]() ![]() ![]() Joined Mar 4, '06 From Ohio Currently Offline Reputation: 10 (100%) ![]() |
Hey, Does anybody know which harness the 3rd plug for the ecm is located. . If I'm correct there is one plug that usually isnt included with the ecm unless you buy the entire clip. I think its with the dash harness. Thanks for your help!!!!!!!!!!!!
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) ![]() |
That's right, it comes from the dash harness, however you have a 22-pin plug in your GT that will work just fine, you just need to repin/rewire it.
Also, some good importers will include the third plug, this is usually the case when I buy engine sets. -Doc This post has been edited by Dr_Tweak: Mar 13, 2006 - 7:12 AM -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Enthusiast ![]() Joined Jan 6, '06 From Toronto, Canada Currently Offline Reputation: 0 (0%) ![]() |
Tweak,
I am trying to get my A/C to work. I understand that the 3rd plug is responsible for turning on the compressor. Do i just repin that plug to match the wires on my interior harness? |
Sort of, yeah. You have to make sure the black/white wire to the a/c compressor clutch is hooked up.
-Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Lo-Fi Version | Time is now: February 26th, 2025 - 1:26 PM |
