> OH NO....., I think she's going to die.
post Mar 13, 2006 - 12:53 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
i have a serious issue guys. its my tranny. i was installing a new set of indiglo gauges from a friend here. at first everything was fine. just didnt have it wired up to a pwr source. when i got to a friends house to get power to the gauges, it worked but when i drove down the street my car acted like it was in neutral and my overdrive button began blinking. it seems like a transmission issue. dr tweak says i may have blown a fuse, so i will go check on that later today. does anyone have any suggestions as to what may be going on?
i talked to a tranny specialist and he pretty much said the same thing, since my speedometer wasnt moving the computer may not know how fast im going and therefore may not know when to tell the car to switch gears. any feedback would be greatly appreciated! biggrin.gif
post Mar 13, 2006 - 1:00 PM
where are you getting your power from?
post Mar 13, 2006 - 2:15 PM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
Your speedometer wasn't working? I'm almost positive now that it's just a blown fuse.
-Doc
Click here to see my swaps
drtweak@phoenixtuning.com
post Mar 13, 2006 - 3:28 PM
hmm your speedo isint working, and you installed indiglow gauges. seems like the needles are getting stuck on your indiglow gauges and thats whats causing you the problem. take the gauges off.
post Mar 13, 2006 - 10:00 PM
Dr_Tweak
Joined Mar 31, '04
We solved the problem, it was a loose connector. All is well again.
-Doc
post Mar 14, 2006 - 10:57 AM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
QUOTE(Dr_Tweak @ Mar 13, 2006 - 10:00 PM) [snapback]407199[/snapback]
-Doc
yup!!! problem solved!!! biggrin.gif biggrin.gif thanx tweak! i dont know how it got loose but i pushed it back in and called the good doctor. by the way, lagos, the needles were getting stuck (that was another problem, so i sanded down the area where the back of the needle was getting friction. (celicab gave me that hint)
Lo-Fi Version Time is now: December 11th, 2024 - 9:09 PM
