> gear box 3s-gte on 3s-ge, help?
post Mar 13, 2006 - 4:56 PM
maikl
Joined Mar 3, '03
From cyprus
does anyone knows if it easy to put an gt-4 gear box on an 3s? what clutch will i need? i am doing this because i've broken mine and because i know that 3s-gte gear box is much shorter than my old...
post Mar 13, 2006 - 5:01 PM
Isn't it bad to disable the RWD portion of the 3S-GTE's tranny for use on a FWD car?
post Mar 13, 2006 - 5:04 PM
maikl
Joined Mar 3, '03
From cyprus
i know that it's a swap that it's been done before but i don't know result's and the proplem's that this swap may have...
post Mar 13, 2006 - 5:13 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
Why don't you just go with the E153? If you use the 4WD trans you'll have to convert it like this:
http://www.celicatech.com/forums/showthread.php?t=11171
This post has been edited by WannabeGT4: Mar 13, 2006 - 5:13 PM
post Mar 13, 2006 - 5:19 PM
maikl
Joined Mar 3, '03
From cyprus
what's E153?
post Mar 13, 2006 - 5:24 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
MR2 Turbo and Camry V6 / Solara transmission.
post Mar 13, 2006 - 5:25 PM
maikl
Joined Mar 3, '03
From cyprus
will it fit easy?
Lo-Fi Version Time is now: January 5th, 2025 - 10:32 PM
