> headlight issues, water leak
post Mar 13, 2006 - 9:46 PM
klm317
Joined Feb 28, '06
From illinois
i just got my 95 celica gt hatch a few weeks ago and i knew that the left bright had a small leak somewhere because there was some slight moisture in it, so i made a post and was told to just use a blow dryer to dry it out. well, we've had a lot of rain lately and i washed it for the first few times(generally once a week if i can), and now i have over 1/4inch of water in the light. so i figure i prolly have a bad seal, but i don't know the best way to take care of it. i could silicone the headlamp shut, but what goes into removing the lamp to do that? any suggestions out there? need to fix this quick bc i don't want to ruin the plastic of the lamp or my wiring frown.gif thanks in advance
This post has been edited by klm317: Mar 13, 2006 - 9:47 PM
post Aug 31, 2006 - 8:24 PM
kcizzle
Joined Jul 12, '06
QUOTE(klm317 @ Mar 13, 2006 - 9:46 PM) [snapback]407188[/snapback]
i have the same problem.. what i did was i removed the round rubber gaskets and let the water evaporate dry. after condensing it and putting back all together.. there is still moisture coming in. i really don't know how to get rid of the moisture. i posted this problem to but they their advice was to seal everything. honestly i still have the same problem right now on both bright lights. have you fixed yours?
post Sep 1, 2006 - 6:40 PM
JFrost9
Joined Aug 27, '05
From Texas
If your still having a problem then that means you obviously didnt seal it right. The answer you got in your other post kcizz is exactly what you need to do. I had this problem, and all i had to do was remove the black gasket, and then i just threw some clear silicone all along the glass/unit. Then put the gasket back on and put more sealant on that part. Works like a charm.
post Sep 3, 2006 - 10:14 AM
HaRv3sTeR
Joined Nov 22, '03
From Tracadie-Sheila, NB (Canada)
QUOTE(JFrost9 @ Sep 1, 2006 - 11:40 PM) [snapback]475295[/snapback]
did the same when i had my stock headlights.....worked pretty well
the key, i guess, is to seal it right
post Sep 5, 2006 - 10:09 PM
kcizzle
Joined Jul 12, '06
thanx. everything is dry now. i hope it stays that way!
Lo-Fi Version Time is now: February 22nd, 2025 - 4:01 PM
