![]() Enthusiast ![]() ![]() ![]() Joined Mar 28, '04 From St.Louis Currently Offline Reputation: 15 (100%) ![]() |
All right, so here goes, this is my first topic post so go easy on me and please don't flame me too much. About 6 months ago i installed the suspension technique's sway bar kit on my 94 GT HB. I had done this previously on my 94 ST Coupe and no problems, so i finished the install on my Gt and went for a test drive around the block. Everything was fine, car drove increasingly better, but the only thing is that any time i go over a slight bump or hole in the road there is a loud knocking/clunking noise coming from the right rear. Now i know that its the sway bar cuse it never had the noise with the stock ones in. So my question is, has anyone ever had this prob, and if so..what do i do to get rid of it? I have tightened the sway bar tot he factory torque, and i have use plenty of lithium grease, so there are no probs, im lost and gettin really annoyed with this noise! PLEASE HELP!
![]() This post has been edited by 94celicadude: Mar 15, 2006 - 1:40 AM -------------------- ![]() 1994 GT Hatchback 1994 ST Coupe 1988 Corolla Wagon All-Trac 1999 Corvette 2008 Cobalt SS Turbo |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 28, '05 From Redondo Beach, CA Currently Offline Reputation: 86 (100%) ![]() |
make sure the end links are tight
QUOTE(LewFX @ Mar 15, 2006 - 4:33 PM) [snapback]407936[/snapback] make sure the end links are tight They are, everything is torqued to the factory specs. -------------------- ![]() 1994 GT Hatchback 1994 ST Coupe 1988 Corolla Wagon All-Trac 1999 Corvette 2008 Cobalt SS Turbo |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 19, '05 From Nebraska Currently Offline Reputation: 4 (100%) ![]() |
What is up with people having so much trouble with these damn sway bars. Maybe it isnt worth my time to install them.........
-------------------- Teh Celica sleeps for Winter '06. Suspension overhaul begins........
check your rear struts and make sure they arent blown then
QUOTE(LewFX @ Mar 16, 2006 - 3:29 PM) [snapback]408509[/snapback] check your rear struts and make sure they arent blown then not trying to come off as an ass, but the struts are new, everything is torqued to factory specs, thanks for your help though, i think i might have left a socket or something like that on top of my gas tank when doing to install and that may be causing it, i might check it out once it warms up a little. Thanks Guys ![]() -------------------- ![]() 1994 GT Hatchback 1994 ST Coupe 1988 Corolla Wagon All-Trac 1999 Corvette 2008 Cobalt SS Turbo |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Dec 9, '05 From Bedford, TX Currently Offline Reputation: 11 (100%) ![]() |
im having the same problem, but for the fronts. when i go on small bumps i hear knocking noise. so today i might check to see if something is loose, so i open my hood and try to tight the middle bolt and its moving, but everytime i try to tighten it, its moving the strut too. so iono what sup with that.
i just had this problem so im stating what i did as well. you stated you tighten the sway bar to factory specs but not the little links that hold the bar and the strut. just because you got new struts doesnt mean you cant blow one going over a bump or hole. maybe your jack in the rear fender is loose. im just going over the madness ive been through lately!
ill take picture and explain what i mean. i replace my blown struts with kyb. i know its not blown, cuz u could feel ur car jumping like crap or when ur turning on the highway, ur going to b flying up and down like a rabbit.
This post has been edited by My2Celi: Mar 16, 2006 - 3:14 PM -------------------- ![]() |
QUOTE(LewFX @ Mar 16, 2006 - 8:00 PM) [snapback]408658[/snapback] i just had this problem so im stating what i did as well. you stated you tighten the sway bar to factory specs but not the little links that hold the bar and the strut. just because you got new struts doesnt mean you cant blow one going over a bump or hole. maybe your jack in the rear fender is loose. im just going over the madness ive been through lately! Ok, i see what your saying, it is possible that ive bblown a strut again, i sure as hell hope not cuse they are new KYB struts, but yea otherwise oeverything in the rear is tightened to factory spec, so who knows, and for My2celi, i think your problem when you say that you try to tighten the middle nut, you actually would need to remove the whole strut to tighten it because there is a flat spot on the shaft of the shock that you need to put a wrench on and then you can tighten that middle nut. Hope that helps. QUOTE(LewFX @ Mar 16, 2006 - 8:00 PM) [snapback]408658[/snapback] i just had this problem so im stating what i did as well. you stated you tighten the sway bar to factory specs but not the little links that hold the bar and the strut. just because you got new struts doesnt mean you cant blow one going over a bump or hole. maybe your jack in the rear fender is loose. im just going over the madness ive been through lately! Ok, i see what your saying, it is possible that ive blown a strut again, i sure as hell hope not cuse they are new KYB struts, but yea otherwise everything in the rear is tightened to factory spec, so who knows, and for My2celi, i think your problem when you say that you try to tighten the middle nut and it turns the whole strut, you actually would need to remove the whole strut to tighten it because there is a flat spot on the shaft of the shock that you need to put a wrench on and then you can tighten that middle nut. Hope that helps. **** double posted, my bad. ![]() -------------------- ![]() 1994 GT Hatchback 1994 ST Coupe 1988 Corolla Wagon All-Trac 1999 Corvette 2008 Cobalt SS Turbo |
![]() Enthusiast ![]() ![]() ![]() Joined Jul 5, '05 From Arlington, TX Currently Offline Reputation: 2 (100%) ![]() |
QUOTE(My2Celi @ Mar 16, 2006 - 1:59 PM) [snapback]408657[/snapback] im having the same problem, but for the fronts. when i go on small bumps i hear knocking noise. so today i might check to see if something is loose, so i open my hood and try to tight the middle bolt and its moving, but everytime i try to tighten it, its moving the strut too. so iono what sup with that. i have same exact problem with front drivers side - i had to jack the car up to clamp the strut still and tighten the bolt on top to keep the strut from moving -- all the other 3 don't do that - so i guess i have one defective one - bad thing is its Tein's - so replacing it would be expensive - |
![]() Enthusiast ![]() ![]() ![]() Joined Feb 24, '05 From Pittsburgh, PA Currently Offline Reputation: 0 (0%) ![]() |
How do u check if u have a bad strut in the back? Thanks -John
QUOTE(Celica_Kid95st @ Mar 16, 2006 - 3:17 PM) [snapback]408705[/snapback] How do u check if u have a bad strut in the back? Thanks -John when i had a bad strut u can feel it bouncy as hell and after taking it out u can extract and retract it like nothing. QUOTE(celicarus @ Mar 16, 2006 - 3:07 PM) [snapback]408699[/snapback] QUOTE(My2Celi @ Mar 16, 2006 - 1:59 PM) [snapback]408657[/snapback] im having the same problem, but for the fronts. when i go on small bumps i hear knocking noise. so today i might check to see if something is loose, so i open my hood and try to tight the middle bolt and its moving, but everytime i try to tighten it, its moving the strut too. so iono what sup with that. i have same exact problem with front drivers side - i had to jack the car up to clamp the strut still and tighten the bolt on top to keep the strut from moving -- all the other 3 don't do that - so i guess i have one defective one - bad thing is its Tein's - so replacing it would be expensive - do you think getting a torque wrench will help? cuz itll spin fast. This post has been edited by My2Celi: Mar 16, 2006 - 10:15 PM -------------------- ![]() |
this part was kinda out, and the nut on top of it is loose. so i held on the strut while my lil bro tighten the top. now its better.
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 17, '04 From Illinois Currently Offline Reputation: 0 (0%) ![]() |
QUOTE(94celicadude @ Mar 14, 2006 - 11:22 PM) [snapback]407809[/snapback] All right, so here goes, this is my first topic post so go easy on me and please don't flame me too much. About 6 months ago i installed the suspension technique's sway bar kit on my 94 GT HB. I had done this previously on my 94 ST Coupe and no problems, so i finished the install on my Gt and went for a test drive around the block. Everything was fine, car drove increasingly better, but the only thing is that any time i go over a slight bump or hole in the road there is a loud knocking/clunking noise coming from the right rear. Now i know that its the sway bar cuse it never had the noise with the stock ones in. So my question is, has anyone ever had this prob, and if so..what do i do to get rid of it? I have tightened the sway bar tot he factory torque, and i have use plenty of lithium grease, so there are no probs, im lost and gettin really annoyed with this noise! PLEASE HELP! ![]() I had the same thing for about 3 weeks and then it just went away. The noise in the front continues though. -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
![]() Enthusiast ![]() ![]() ![]() Joined Mar 14, '05 From Auckland,New Zealand Currently Offline Reputation: 1 (100%) ![]() |
QUOTE(jgreening @ Mar 18, 2006 - 8:05 PM) [snapback]409543[/snapback] I had the same thing for about 3 weeks and then it just went away. The noise in the front continues though. Can't find a fix? Is it just when you go over bumps or sometimes when you turn as well? Mine does it and I am not sure if it is my shocks. |
No its only when i go over bumps or holes, never when i turn. And its been going on for months now.
Lo-Fi Version | Time is now: February 24th, 2025 - 5:14 AM |
