5 Pages V  < 1 2 3 4 > »
> Help Update: Speedo Still Not Working
post Mar 16, 2006 - 2:21 PM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
Chan, give me a call if you like. 802-334-6553.
-Doc
Click here to see my swaps
drtweak@phoenixtuning.com
post Mar 16, 2006 - 2:43 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
There is a less complicated way to accomplish the same exact thing RJB has suggested.
On the COR plug there is a black and a black-yellow wire. They need to be connected together like this:
post Mar 16, 2006 - 3:09 PM
Rjb23
Joined Feb 8, '04
From KY
I don't think there is a black and black yello wire on the cor, but yea that is the idea. Remember his harness is not the same as the stock 5s harness. Doc will get him straight.
post Mar 16, 2006 - 3:12 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
Wirings diagrams for both the 90-91 and 92-93 3SGTE show a black and black yellow wire on the COR just like the 5SFE COR. I'd have to go take a look at my harness at home to be 100% sure though.
post Mar 16, 2006 - 3:15 PM
Rjb23
Joined Feb 8, '04
From KY
Yea me too but if I remember right I didn't have one because my car was an auto so it was missing that wire.
This post has been edited by Rjb23: Mar 16, 2006 - 3:16 PM
post Mar 16, 2006 - 3:31 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
Auto and Manual COR wiring should be the same... even between AT200 and ST204, but again, this is just according to the wiring diagrams i have.
post Mar 16, 2006 - 5:44 PM
Chanh55
Joined Jun 29, '03
I gave doc a call, I will give his suggestion a try. I'll post about it if it works as it is good to know if you're doing a swap and you have an auto.
post Mar 16, 2006 - 11:08 PM
Chanh55
Joined Jun 29, '03
Bump, please see page 1.
post Mar 17, 2006 - 12:09 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
QUOTE(Rjb23 @ Mar 16, 2006 - 2:15 PM) [snapback]408671[/snapback]
QUOTE(WannabeGT4 @ Mar 16, 2006 - 2:31 PM) [snapback]408679[/snapback]
Both my 3S harness and my 5S harness have the black and black/yellow wires.
post Mar 17, 2006 - 6:22 PM
Dr_Tweak
Joined Mar 31, '04
Yes, but the black wire goes to a different place on the 3SGTE diagrams. Trace it out and you'll see what I mean.
-Doc
post Mar 18, 2006 - 7:06 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
QUOTE(Dr_Tweak @ Mar 17, 2006 - 5:22 PM) [snapback]409334[/snapback]
-Doc
Yeah, That was just a simpler way to accomplish the same thing RJB suggested. I didn't do his harness so it's a good thing you cleared that up for him.
post Mar 20, 2006 - 5:35 PM
Chanh55
Joined Jun 29, '03
My speedometer isn't working. I checked all the plugs and they're all tight. I removed the cruise control unit... do you think this has anything to do with the speedometer not working?
OK, just talked to the previous owner of the engine... he said after El Prototype redid the wiring, the speedometer stopped working. So I'm thinking there's a missing connection between the gauge and the speed sensor.
Can someone help me out?
This post has been edited by Chanh55: Mar 20, 2006 - 6:07 PM
post Mar 20, 2006 - 10:25 PM
Dr_Tweak
Joined Mar 31, '04
Here you go Chan:
That's what we talked about over the phone, if you can mimick that circuit you should be set. You'll find the wires you want at II1 pins 12 and 13, and II2 pin 10. Red/blue, blue/black, and blue.
-Doc
This post has been edited by Dr_Tweak: Mar 20, 2006 - 10:26 PM
post Mar 21, 2006 - 1:14 AM
DG_Performance
Joined Jun 21, '03
From Pennsylvania
The easy way to do it.... i am guessing you will not be able to read that diagram so just do the following.
Plug IG2#3 goes to Plug II2#10
Plug IG2#4 goes to Plug II1#12
Plug IG2#12 goes to Plug II1#13
DG
post Mar 21, 2006 - 1:16 AM
Chanh55
Joined Jun 29, '03
QUOTE(DG_Performance @ Mar 20, 2006 - 10:14 PM) [snapback]410815[/snapback]
DG
I'm looking at the diagram with all the connectors/ plugs, which one is II1? Is that connected to the ECU or is it one of those ones with the 3 verticle connectors near the ECU?
This post has been edited by Chanh55: Mar 21, 2006 - 1:18 AM
post Mar 21, 2006 - 1:17 AM
DG_Performance
Joined Jun 21, '03
From Pennsylvania
You can kiss me later....
NOT!
II1 is one of the plugs under the radio...grey, 5pins on top... 8 on bottom
DG
This post has been edited by DG_Performance: Mar 21, 2006 - 1:23 AM
post Mar 21, 2006 - 1:26 AM
Chanh55
Joined Jun 29, '03
QUOTE(DG_Performance @ Mar 20, 2006 - 10:17 PM) [snapback]410819[/snapback]
NOT!
DG
Cool thanks. I'll should be able to test it Wednesday when my new AFM comes. smile.gif
post Mar 21, 2006 - 6:50 PM
madmods
Joined Mar 19, '04
From Scottsdale, Az
Chann, you made this comment on another post:
It's literally scary fast... I'm scared to driver her right now... and the car makes all kinds of noises... to name a few... the whinebro fuel pump, blow off valve, turbo spooling... loud exaust... it's definately not your normal commuter car anymore.
So in all honesty, do you like it? What are the pros and cons to her?
post Mar 21, 2006 - 7:05 PM
Chanh55
Joined Jun 29, '03
Well...
1. I drove to the mufflerr shop with a bad AFM (Air Flow Meter) to get my testpipe and she breaks down on me like 3 times....in the middle of the road, pretty embarrassing. So now, I'm not really trusting her.
2. I'm really used to driving around in an automatic...now I have to adjust to a manual, on top of that a Stage II clutch. I've stalled a few times already. BTW I do know how to drive stick... just takes a little time adjusting to the Stage II.
3. I did most of the work myself... I never even changed my oil before... how the hell am I supposed to know I didn't do something wrong?
But all in all... I can't believe I have a 3sgte under my hood! It still hasn't hit me yet... Like I said... I just need a little time to adjust.
post Mar 22, 2006 - 12:45 AM
madmods
Joined Mar 19, '04
From Scottsdale, Az
QUOTE(Chanh55 @ Mar 22, 2006 - 12:05 AM) [snapback]411083[/snapback]
Well...
I guess I should refrain the question. Talk to me about the power! The scary fast is what I am interested in.
plus congratulations on the swap. lagos once said that a swap would make you a good mechanic, and i have
to agree with him. I'm sure your on the way there.
Lo-Fi Version Time is now: January 10th, 2025 - 10:21 PM
