Enthusiast ![]() ![]() ![]() Joined Jan 9, '05 From Under the car Currently Offline Reputation: 0 (0%) ![]() |
QUOTE(lantz2121 @ Mar 29, 2006 - 6:43 AM) [snapback]414922[/snapback] QUOTE(Insanity-74 @ Mar 29, 2006 - 5:35 AM) [snapback]414911[/snapback] The st205 antilag isnt active on road cars so I dont see why you need to connect it, I dont know if it serves another purpose though...I dont think it does......Will check out the TB plug tonight when I get back from work. Kewl so just the one vtv or vsv should be fine As far as I know...but i dont know if they serve another purpose or not??? You had best check just in case. |
Right....just had a quick look for ya......around the throttle body there are 4 connections that I can see....one goes to the throttle position sensor on the right hand side of the TB...another is a temp sensor under the throttle body. One connects to a temp sensor in the inlet manifold right next to, and slightly down from the RH side of the TB...another on the left goes to the inlet manifold pressure sensor on the bulkhead, so its quite a long lead....thats all I can see. All the others from that part of the loom go to injectors.
![]() Enthusiast ![]() ![]() Joined Jan 22, '06 From Melbourne, Australia Currently Offline Reputation: 0 (0%) ![]() |
speaking of temp sensors... is there any way of tapping into the temp sensor on the intake manifold? Seems easier than drilling into the throttle body to attach a temp sensor
![]() -------------------- www.tangcla.com - photography
Canon EOS 5D Mark II | EOS 1D Mark II N | 16-35mm f/2.8L |24-70mm f/2.8L | 70-200mm f/2.8L IS 15mm f/2.8 fisheye | 85mm f/1.8 | 100mm f/2.8 macro | 580EX-II x2 |
I wouldnt, incase you get false readings and **** up the car....its easy to drill into the manifold and tap it for a sensor...just make sure you get all the swarf out or it`ll be sucked into your engine...then its good night vienna.
Lo-Fi Version | Time is now: February 20th, 2025 - 7:50 AM |
