NAWS quick question |
Mar 16, 2006 - 8:50 PM |
Enthusiast Joined Jun 19, '05 From New York Currently Offline Reputation: 1 (100%) |
anone runnig nitrous, wondering if u had to change anything before it was "ok" to run, i heard spark plugs should be changed and maybe some other stuff?.. any comments besides its stupid and dont do it ur gonna blow ur motor, would be helpful
Mar 16, 2006 - 8:52 PM |
spark plugs and fuel...just make sure to run a wet kit not a dry
This post has been edited by playr158: Mar 16, 2006 - 8:52 PM |
Mar 16, 2006 - 8:53 PM |
fuel, meaning what?
direct port wet This post has been edited by TheStreetzKing: Mar 16, 2006 - 8:53 PM -------------------- |
Mar 16, 2006 - 11:08 PM |
Nick...NO
I said NO! -------------------- |
Mar 16, 2006 - 11:13 PM |
lol its only gonna be for purging but jus gathering some info
Mar 16, 2006 - 11:18 PM |
you want to your fuel system, like injectors, fuel pump, fuel rail... pretty much anything fuel related.
Mar 17, 2006 - 5:52 PM |
Enthusiast Joined Oct 17, '04 From St Louis, MO Currently Offline Reputation: 0 (0%) |
fuel pressure safety switch, 1 step colder plugs, make sure your timing is stock or a few degrees retarded...
-------------------- 2005 MB C200 Kompressor- K&N, Apexi WS2 Catback, DIY Voltage stabilizer, Intrax Springs, H&R RR swaybar, VDO Boost Gauge @ 6psi, Greddy L7 plugs, +0 Rear tires
To Do: E-manage Ultimate tuned up to 12psi |
Mar 19, 2006 - 9:58 AM |
Enthusiast Joined Jan 16, '06 From Lima, ohio Currently Offline Reputation: 0 (0%) |
a wet sysetem also controls and adds extra fuel into the intake as well, if i am not mistaken but i might be because i havent done any resarch on this in a grip
Mar 19, 2006 - 10:28 AM |
Enthusiast Joined Jun 21, '05 From New york Currently Offline Reputation: 1 (100%) |
i am running nitrous and am very disappointed with the power gain i get from it. The purge is cool on it but dont spend that kinda money on a nitrous kit for the purge and be wasting the nitrous, it is expensive to fill it up everytime also. do what they said, make sure you have enough fuel, cuz sometimes when i spray i get to lean and detonation occurs. Also colder spark plug is a must, and retarding the timing. And it isnt NAWS, it is nitrous, NOS is a brand of a company that sells Nitrous kits. lol
Bigal -------------------- 1994 celica GT.....3sgte in a month! all helpers are welcome!!! i live in Plattsburgh, NY.
Mar 19, 2006 - 8:54 PM |
the whole NAWS was a joke, i have a kit already, NOS wet system
Mar 19, 2006 - 9:01 PM |
QUOTE(TheStreetzKing @ Mar 19, 2006 - 8:54 PM) [snapback]410116[/snapback] the whole NAWS was a joke, i have a kit already, NOS wet system oh noes -------------------- 15PSI - 30MPG - Megasquirt Tuned
Mar 19, 2006 - 9:42 PM |
For a celica wet is prolly the way to go, because these are older cars and they prolly cant take too much detonation.
Mar 19, 2006 - 11:36 PM |
Enthusiast Joined Aug 30, '02 From Anaheim, CA Currently Offline Reputation: 0 (0%) |
upgrade the fuel pump
full tune up retard timing use conservativly that will get you a setup that will be fairly reliable, given that you start out with a healthy motor and dont run too big of a shot i ran a 100shot through my WRX. it was fun, but expensive -------------------- 1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram |
Mar 19, 2006 - 11:51 PM |
i wouldnt trust it on my motor, let alone a stock 5sfe. will it work, sure? youll get a few joy rides out of it, but pretty soon you can bet there will be some internal damage.
Mar 21, 2006 - 12:43 AM |
Enthusiast Joined Oct 13, '02 From Blairstown, New Jersey Currently Offline Reputation: 6 (100%) |
I think theres alot of misconceptions around here concerning the effectiveness and safety of nitrous.
First off, just because it has an unfortunate ricer connotation when you hear the phrase "NOS" or "NAWWS" doesn't mean that it isn't an extremely effective way of squeezing that much more power out of your motor safely. Sure there are added stresses involved....but if you keep the shot within the tolerances of the motor and have a professionally tuned fuel and timing map it shouldnt be unreasonable to run on a more frequent basis with great results. Also, using nitrous on a boosted motor isn't such a horrible thing....it can reduce detonation and cool your boost significantly if you're running a highly pressurized motor. Its a great option to use in drag racing if you eed to cram out some extra power, but of course only if you can support and tune in the nitrous' presence. If you don't tune properly, then of course you'll blow your motor. Thats a given. Alot of systems probably don't work as reliably or effectively as the ycould because they use a very simple interface designed for ease of installation and easy operation to get the job sort of done. But if you utilize a colder plug, retarded the timing or used an ignition device that would progressively retard the timing according to the ammount of knock/ air fuel ratio, and an upgraded fuel system then I don't see why it would be a bad thing at all. In fact, I'd like to see what somebody could do with a setup like that. This post has been edited by Silver94CelicaOwner: Mar 21, 2006 - 12:45 AM -------------------- 3rd gen ST205 3SGTE - Alive and boosting. |
Lo-Fi Version | Time is now: December 4th, 2024 - 6:00 AM |
