> ABS light
post Mar 18, 2006 - 12:15 AM
bigal004321
Joined Jun 21, '05
From New york
So my ABS light has been on for about a year now and i havent really payed much attention to it, though it only comes on a short while after start up, and my brakes my this skipping grinding noise when it is on. Any ideas would be helpful!! smile.gif
1994 celica GT.....3sgte in a month! all helpers are welcome!!! i live in Plattsburgh, NY.
post Mar 18, 2006 - 12:19 AM
the ABS is not part of your ECU CELs. The ABS has it's own ABS ECU and if there is a prob with the system (sensor or whatever) it shuts the system down and you have normal braking ability and the ABS light will remain illuminated. You can then read the ABS codes
for reference...
94-95
ignition in the ON position,
bridge E1 & TC in the diagnostics box, just like checking codes, read the code from the ABS light
codes 31-34 are the sensors @ each wheel.
31 Malfunction of right front wheel speed sensor signal. Check
speed sensor, sensor rotor, wiring harness and connector
32 Malfunction of left front wheel speed sensor signal. Check
33 Malfunction of right rear wheel speed sensor signal. Check
34 Malfunction of left rear wheel speed sensor signal. Check
speed sensor, sensor rotor, wiring harness, and connector
if you do not have a 94-95 you can go to Autozone or Pep Boys and they can check the code for free I believe
post Mar 18, 2006 - 1:03 PM
bigal004321
Joined Jun 21, '05
From New york
alright thatnks for the help. Is there a place where i can find a complete list of codes.
QUOTE(Batman722 @ Mar 18, 2006 - 12:19 AM) [snapback]409476[/snapback]
for reference...
94-95
Lo-Fi Version Time is now: February 24th, 2025 - 8:18 AM
