> car like to stay at 2500rpms
post Mar 18, 2006 - 1:13 PM
bigal004321
Joined Jun 21, '05
From New york
OK sometimes my car likes to stay revved at 2500RPMs or higher. It is usually happens after i rev it or drive it hard, but sometimes jsut normal driving too. I was just wondering if it was a vacuum leak or what? Because i cant figure it out.
1994 celica GT.....3sgte in a month! all helpers are welcome!!! i live in Plattsburgh, NY.
post Mar 18, 2006 - 5:31 PM
Guest_TurbO_*
yeah mines like that too...trying to figure out what the problem is...but i dont have any leaks...i checked everything and just can't seem to figure out...the celica is giving me problems...i might have to sell and just drive my 92 corolla...the 92' doesn't give me any problems at all?...too much problems for the celica...
post Mar 18, 2006 - 10:23 PM
bigal004321
Joined Jun 21, '05
From New york
yeah the celicas is a weird car sometimes, but i love her too much to let her go! plus i am getting a new engine anyways so might as well keep it.
This post has been edited by bigal004321: Mar 18, 2006 - 10:47 PM
post Mar 19, 2006 - 4:52 PM
pimpstarr690
Joined Jul 19, '04
From Strongsville, Ohio
Try to run a scan tool and see if and check the trouble codes on it, might be a knock sensor or something else...
My Twins!
post Mar 19, 2006 - 5:33 PM
94CELICAGT_98584
Joined Oct 27, '05
From Olympia, Washington
Make sure there isnt a leak between the PCV and the intake manifold hose. When you disconnect the hose the RPM's will shoot up and stay at around 2500 RPM. Hope that helps!
!!KANER!!
post Mar 19, 2006 - 6:25 PM
CheesyLobster
Joined Jul 19, '04
From Los Angeles, CA
make sure your throttle line isn't snagged on anything and make sure that your throttle position sensor is good and all the wires are connected well.
post Mar 19, 2006 - 8:18 PM
Guest_TurbO_*
QUOTE(94CELICAGT_98584 @ Mar 19, 2006 - 5:33 PM) [snapback]410023[/snapback]
where are those located?
post Mar 19, 2006 - 9:33 PM
94CELICAGT_98584
Joined Oct 27, '05
The PCV comes directly off the top of the valve cover and there is only like a 5 inch hose that runs right into the front of the intake manifold.
!!KANER!!
post Mar 19, 2006 - 9:44 PM
bigal004321
Joined Jun 21, '05
From New york
Lo-Fi Version Time is now: November 23rd, 2024 - 8:32 AM
