> Air Fuel Ratio Guage?, Which Wire is the o2 sensor from ECu
post Jun 1, 2003 - 12:15 AM
D-No-One
Joined Feb 9, '03
From St Paul MN
does anyone done installing an Air fuel ratio guage? im wondering does anyone know which wire from the ecu is the o2 sensor. i have a 94 toyota celica gt.
Thanks
post Jun 1, 2003 - 12:25 AM
No0bOne
Joined Jan 5, '03
From Bay Area
...why do you need a guage in your 6GC? what mods has been done to it so far?
post Jun 1, 2003 - 12:31 AM
D-No-One
Joined Feb 9, '03
From St Paul MN
turbo kits....
post Jun 1, 2003 - 12:36 AM
D-No-One
Joined Feb 9, '03
From St Paul MN
QUOTE (D-No-One @ May 31, 2003 - 9:29 PM)
Thanks
post Jun 1, 2003 - 3:36 PM
94celicaguy
Joined Nov 11, '02
why dont you just hook it up to the o2 sensor off the exhaust manifold? thats what i did and it works great
post Jun 1, 2003 - 7:33 PM
D-No-One
Joined Feb 9, '03
From St Paul MN
i did hook it up to the o2 wire sensor but some how there is no more power.. did i burn that air fuel ratio guage? anyone know?
post Jun 1, 2003 - 9:25 PM
snadman
From Minnesota, USA
LOL. I hope you didn't connect it between the O2 Sensor and the connector...cuz that's wrong. There's a connector a few inches up...after that's it's a single shielded wire. Splice into that one.
95 Toyota Celica GT
Dead for now --> Soon to have a 3S-GTE
02 WRX --> This is for speed
- Borla Exhaust
- TurboXS BOV
- Custom CAI
02 Civic EX
- MB Quart Reference 5.25" Components
- Rockford MTX 8" Subs in the doors
- Alpine Type S Rear Fills
- 2x Alpine SWR-1042D Subs in a custom fiberglass box
- Alpine F345 Amp for the front doors
- Alpine M605 on each Type R
- Phoenix Gold wiring
- Alpine CDA-9855 Head Unit
- Alpine Amp link
- 2x Rockford Fosgate 1 Farad Caps
- The best Viper 791 alarm install ever
post Jun 1, 2003 - 9:28 PM
snadman
From Minnesota, USA
Also, make sure your power wire and ground wire are correctly spliced...just check all connections. Mine worked right away. What kind did you get? I want the AutoMeter one but couldn't fork up the dough...so I got some cheapie from AutoZone...works nicely though.
95 Toyota Celica GT
- Borla Exhaust
- TurboXS BOV
- Custom CAI
02 Civic EX
- Alpine Amp link
post Jun 1, 2003 - 9:50 PM
6gencelica
Joined Mar 30, '03
From pennsylvania
i hooked mine up to the exhaust manifold and it works fine. i have had it for two years w/o a problem. to see if you broke it, just take your power wire to the battery and your ground wire to the ground on your battery. if the led lights up, then it is fine. if it doesnt light up, it might be broke. i dont know to much about electronics, and theres probably a smarter (or more technical) way to do this, but that works for me. -Dan
post Jun 2, 2003 - 3:12 PM
snadman
From Minnesota, USA
OK. Well, it won't work. At least mine doesn't work like that. you need a voltage reading on that wire that gos to the O2 sensor wire to get the LEDs to light up.
95 Toyota Celica GT
- Borla Exhaust
- TurboXS BOV
- Custom CAI
02 Civic EX
- Alpine Amp link
post Jun 2, 2003 - 11:39 PM
6gencelica
Joined Mar 30, '03
From pennsylvania
on the autometer one, it is just a bunch of leds that move from lean to rich and if you have power but your o2 sensor is not hooked up, the led all the way to the left stays lit...i was explaining how mine worked, yours may be different snadman confused.gif
post Jun 3, 2003 - 12:40 PM
D-No-One
Joined Feb 9, '03
From St Paul MN
thanks guys..i got it works.....got some infor from toyotacelicaonline.com
This post has been edited by D-No-One: Jun 3, 2003 - 12:41 PM
Lo-Fi Version Time is now: November 24th, 2024 - 3:48 PM
