ebay and ct26, equal good? |
Mar 19, 2006 - 1:34 AM |
Enthusiast Joined Feb 25, '03 From Springfield, MO Currently Offline Reputation: 1 (100%) |
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...me=STRK:MEWA:IT
does this see mlike a good price? i am wanting between 250-300hp max -------------------- Coming in 2010 full paintjob - new wheels - modified body - new interior - engine build- marriage |
Mar 19, 2006 - 1:54 AM |
Enthusiast Joined Aug 14, '05 From Corpus Christi Tx Currently Offline Reputation: 5 (100%) |
what are you planning on doing? A 3s swap or a turbo setup with ur 5s.
Either way IMHO that turbo is not worth it at all bacause it has WAY to many miles on it and its not the turbo you want. You want to get the dual entry st185 found on the all-tracs and mr2s oh btw, if ur planning on a turbo setup with ur 5s then your hp goals are a little too high. Your looking at about 190-200whp at the most. |
Mar 19, 2006 - 2:17 AM |
thanks for the info and corrections.
planning to add turbo to 5sfe. This post has been edited by b1gr3d: Mar 19, 2006 - 2:18 AM -------------------- Coming in 2010 full paintjob - new wheels - modified body - new interior - engine build- marriage |
Mar 21, 2006 - 12:02 AM |
another question i have is that what type turbo is recommended for a 5sfe? i have read a lot of posts on turbos and i get confused becuase there is talk about mapping anf all this stuff.....i want the low down basics on what i need to look for.
goals: -as mush HP as i can get with stock internals -turbo to kick in at decent rpm, but not be spooling the whole time i am going 65 with the cruise on(if not possible i'm fine with it) -doesn't cost arm and a leg info i need: -what will work within my requirements -what do i need to look for(trim and what not) -what to avoid thanks for the help.--I'm in Laramie,WY visting wyotech and i have seen 2 or 3 5th gen all trac's wowza -------------------- Coming in 2010 full paintjob - new wheels - modified body - new interior - engine build- marriage |
Lo-Fi Version | Time is now: December 3rd, 2024 - 4:30 PM |
