> wheel spacers?
post Mar 19, 2006 - 4:18 PM
rzanology
Joined Apr 25, '05
From nyc
Do you guys use wheel spacers? Is there any down side to using them? I would like to bring my wheels out about 1\2 inch in the front and and inch in the back....what do you guys thinkg?
post Mar 19, 2006 - 6:10 PM
very few people here seem to use spacers, but they are very common in the domestic and truck market.
i thought about getting some for my car, but always put it off. part of me, dosnt like the idea of a large spacer that has to bolt on to your existing lug nuts. but i have talked to a few people that have used them for years without problems.
if u buy them, only get H&R hubcentric spacers.
post Mar 19, 2006 - 6:34 PM
jgreening
Joined Jan 17, '04
From Illinois
QUOTE(lagos @ Mar 19, 2006 - 5:10 PM) [snapback]410033[/snapback]
some spacers (like mine) come with longer lugs which is a better idea, IMO.
post Mar 20, 2006 - 11:43 AM
Nampetch
Joined Apr 30, '04
From Thailand
QUOTE(rzanology @ Mar 20, 2006 - 4:18 AM) [snapback]410011[/snapback]
I have been using custom made spacer all around. front = 1.7 cm rear 0.7 cm. almost 2 year with no problem...
The key point for spacer is:
1. Center bore of your wheel and spacer must be perfectly match and sit tie. this will ensure that there will be "no shake" when driving..
2. You stud if necessary may need to be replaced with longer stud.
goodluck...
post Mar 20, 2006 - 12:11 PM
tufy
Joined Dec 3, '03
From Cyprus
QUOTE(rzanology @ Mar 19, 2006 - 9:18 PM) [snapback]410011[/snapback]
its all about the offset and the with of your rims.
if your offset is low you can use spacers to raise it. i am planning to use 5 mm spacers at rear so my rims will look like 8.5'' but i have 8''. To use 25 mm spacer is too much i think... what is your rims size and offset?
post Mar 20, 2006 - 12:27 PM
rzanology
Joined Apr 25, '05
From nyc
by offset you mean the tire width? if so its 7.5. They look too much like stock to me...infact i'd swear stock rims look wider than mine. which is why i want to use the spacers.....bring the tire out of the wheel well some more. But i think my problems also lies with the rim....i dont have deep dish. i notice alot of you guys who get that really aggrisve look im looking for have deep dish. You think that would help?
heres two pics of the rims...one from the side and the back....
This post has been edited by rzanology: Mar 20, 2006 - 12:28 PM
Lo-Fi Version Time is now: February 23rd, 2025 - 7:52 PM
