![]() Enthusiast ![]() ![]() Joined Jan 13, '06 Currently Offline Reputation: 0 (0%) ![]() |
hey guys can i manually retard my timing on my 95 corolla 7afte?
![]() Enthusiast ![]() ![]() Joined Aug 18, '04 From Silverdale, WA Currently Offline Reputation: 0 (0%) ![]() |
Yes just loosen the bolts on the distributor and rotate it. I don't remember what direction it is but if you have a timing light setup then just check it with that. This link should help you.
http://aarc.epnet.com/application/8959/895...JUSTMENT.htm#T2 |
great info bindertch .
I don't want to get that msd btm. What Problems will I have if i just retard 5 degrees. by moving the dizzy. i'm running like close to 5psi kick it up to 8 soon.
or am i confused? |
QUOTE(southwest2118 @ Mar 27, 2006 - 2:04 AM) [snapback]413760[/snapback] I don't want to get that msd btm. What Problems will I have if i just retard 5 degrees. by moving the dizzy. i'm running like close to 5psi kick it up to 8 soon. or am i confused? you'll notice a lack of low end power and possibly a drop in highway mileage. im not even sure if its adjustable on the 95. if you have 2 hold down bolts than it is, if its only one then its not adjustable. your best bet is to get a piggyback system like an emanage that can control timing and fuel curves as well as some other features. -------------------- |
Lo-Fi Version | Time is now: February 23rd, 2025 - 10:32 AM |
